Since 2016, I have been successfully using Homebridge v.0.4.38 on a Raspberry Pi 4 to control my 10 Home Automation Photons with my voice commands (Apple Siri).
It has been working like a charm! But recently I start to get more issues with it.
So, I tried to migrate to the new Homebridge version 1.4.0.
BUT, I am getting nowhere after spending a complete Sunday to make something work… ![]()
I wonder if some of you have it working already?
What did I do?
I used a new SD card to install a fresh Raspbian system, then I installed Homebridge, following these instructions: LINK
- Install latest Node.js
- Install new Homebridge and Homebridge UI versions
- Install and configure the new Particle plugin “homebridge-particle-io” by @nthomas:
LINK2
"bridge": {
"name": "Homebridge",
"username": "CC:22:3D:39",
"port": 51826,
"pin": "031-45-15x"
"description": "This is an example configuration file with one Particle platform and 3 accessories, two lights and a temperature sensor.",
"platforms": [
"platform": "ParticleIO",
"name": "Particle Devices",
"access_token": "d12f64d44etc…",
"cloud_url": "https://api.particle.io/v1/devices/",
"devices": [
"name": "Light1",
"type": "lightbulb",
"device_id": "d12f64d44etc…",
"function_name": "onoff",
"args": "0={STATE}"
"name": "Light2",
"args": "1={STATE}"
"name": "Temperature1",
"type": "temperaturesensor",
"device_id": "d12f64d44etc…..",
"event_name": "tvalue",
"split_character": ":"
"name": "Config",
"port": 8581,
"platform": "config"
"accessories": []
This configuration file creates 2 light switches and one temperature sensor. I can see them appear in the Homebridge Graphic UI in my browser.
But when I toggle the switches, the state changes only very briefly from OFF to ON and then OFF again. In the temperature button, no temperature is indicated, although I can see in the logs that the Particle message with “temperature:20” is received. In the Particle console I can see that the commands “1” and “0” are received and the respective commands (Publish “Light ON or OFF” are working.
FYI: This is the sketch running on a test Photon:
// Testing a Photon (Internet button) on NEW Homebridge v1.4.0
Particle.function("onoff", onoff);
Particle.publish("tvalue", "temperature:20");
delay(60000);
int onoff(String command)
if(command == "1")
Particle.publish("Homebridge", "Light ON");
return 1;
if(command == "0")
Particle.publish("Homebridge", "Light OFF");
return 0;
Particle.publish("Homebridge", command);
return -1;// If none above
I have 2 questions:
- What is wrong with this setup that no temperature is shown?
- Is it not possible anymore to add an argument to the command like it was in the older plugin (by @krvarma)? It allowed me to control a virtually unlimited number of devices with one photon…
On top of these issues, I could not add the Homebridge buttons to the Apple HOME app. I get an error message after scanning the QR code…
Thanks for your time!
Filip
