Device OS 1.4.2 Default Release is out on the Web IDE for (Core/Photon/P1/Electron/Argon/Boron/Xenon/A SoM/B SoM/X SoM)
released on production servers October 18th, 2019
Please read all notes below ![]()
Note: This is a Release and may be used for production. Any known issues are likely slated for a future version, (check Github issues). It is available by default for all devices. To use, select the 1.4.2 version dropdown from the devices drawer.
Downgrading back to a previous release info is at the bottom of this post.Note: If you have previously last used one of the prerelease or release versions of 1.4.x on a device, please re-flash it with 1.4.2.
- Then update to 1.4.2
- You may update to 1.4.2 directly first, flash the system firmware (attached above) in order 1,2(,3) to the device using
particle flash --usb <system-part.bin>. See the next note about the bootloader if you are offline!Note: P1/Photon Bootloader
The Cloud will automatically update the bootloader on P1/Photon devices if your device is online. If your device does not connect to the cloud and it is offline, you should flash the bootloader to the device usingparticle flash --serial <bootloader.bin>. This should be done after upgrading system firmware. The Electron bootloader is applied automatically from it's own system parts.Note: Argon/Boron/Xenon/Argon-SoM/Boron-SoM/Xenon-SoM Bootloader
If your device is offline, the bootloader must be manually updated usingparticle flash --serial <bootloader.bin>. This can be done before or after upgrading system firmware.Note: Argon/Boron/Xenon/Argon-SoM/Boron-SoM/Xenon-SoM SoftDevice
If your device is offline, the SoftDevice must be manually updated using the CLI. See the instructions below.Note: Downgrading [Electron/Photon/P1] OTA or YModem transfer:
1.4.2
Note: If your Gen 2 Photon/P1 or Gen 3 device does not have a Cloud connection, it is recommended to update system firmware via CLI with
particle update. Electron bootloaders are still contained in system firmware and will update automatically as needed.
This release contains v501 bootloaders.
SoftDevice update
Prerequisites
particle-cli version 1.49.0.
Upgrading using particle update
- Put the device into DFU mode
- Run
particle update
DeviceOS, bootloader and SoftDevice should get correctly updated.
Upgrading OTA
- Upgrade to 1.4.2
- Manually flash 1.4.2 bootloader:
particle flash <deviceId> boron-bootloader@1.4.2.bin - Flash SoftDevice:
particle flash <deviceId> boron-softdevice@1.4.2.bin
Upgrading using YModem
- Upgrade to 1.4.2
particle flash --serial boron-bootloader@1.4.2.bin - Flash SoftDevice:
particle flash --serial boron-softdevice@1.4.2.bin
- Upgrade Device OS to 1.4.2
- Update the bootloader to 1.4.2 with the OTA or YModem process above
- Flash the SoftDevice:
particle flash --usb boron-softdevice@1.4.2.bin
BUGFIXES
- [Gen 3] Fixes a boot/crash-loop due to a
POWER_CLOCK_IRQnfiring in between the jump into the system firmware from the bootloader #1948
System Binaries (all devices)
https://github.com/particle-iot/device-os/releases/download/v1.4.2/particle_device-os@1.4.2.zip
Programming and Debugging
