I guess we know that Particle Dev is still in development so we can expect a few hiccups. Everything was going fine and then I got the dreaded
`"(!) build didn’t produce binary Error: Command…"
If I clicked on it, it reported at the top of the page:
"There were no compile errors"
It was a large file and I wasted a bunch of time; eventually, as suggested above, I used the command line compile which helped identify a typo.
I managed to replicate the phenomenon in a small file, as follows:
// Function prototypes
int myFunction(String foo);
Serial.begin(115200);
Particle.function("myFunction", myFunction);
int aFunction(String foo) {
Serial.println(foo);
return 1;
Note the “typo”: myFunction(), listed as a function prototype, doesn’t match aFunction() declared later. It works of course if aFunction() is changed to myFunction().
The point is that Particle Dev won’t build a binary but doesn’t find an error. How do I flag this for the development guys?
My advice to others is that if you get a “build didn’t produce a binary” go immediately to command line compile for extensive warnings and error messages.
