With my Core tray to exercise with the attached code. If I’m flashing with the build from your Web page the code working and led D7 is blinking. If I flashing with Particle Dev on my pc dosen’t work. Are there a reason?
Thanks a lot Vale
Code is not building from me but copy in internet:
const int buttonPin = D4; // the number of the pushbutton pin
const int ledPin = D7; // the number of the LED pin
// variables will change:
int buttonState = 0; // variable for reading the pushbutton status
// initialize the LED pin as an output:
pinMode(ledPin, OUTPUT);
// initialize the pushbutton pin as an input:
pinMode(buttonPin, INPUT);
// read the state of the pushbutton value:
buttonState = digitalRead(buttonPin);
// check if the pushbutton is pressed.
// if it is, the buttonState is HIGH:
if (buttonState == HIGH) {
// turn LED on:
digitalWrite(ledPin, HIGH);
} else {
// turn LED off:
digitalWrite(ledPin, LOW);
