hi, i am playing around with particle. i connected a microphone and have some calculations running on it, but when i trigger the Particle.publish()… it crashes after a few seconds with 10 times blinking red after the SOS
here is the code:
* record microphone, write to serial
#include <stdio.h>
void apply_filter(double wave[]);
void ifSomeoneWasTalkingSendEvent();
void tabelle2();
#define FILTER_COUNT 17
#define FILTER_MITTELWERT FILTER_COUNT/2
double filter_value[] = {-0.06871842412524538,
0.030806641388861217,
0.04196636574643017,
0.0596784709979785,
0.08054585311515544,
0.1012312882292675,
0.11862582117408683,
0.13018226286688447,
0.13422859623430416,
0.1012312882292675,
0.0596784709979785,
-0.06871842412524538};
const int microphone = A0;
const int buttonPin = D5;
const int ledPin = D7;
const int recLength = 8192; // 2 hoch 13, 250 ms
const int abtastrate = recLength;
double wave[recLength];
unsigned long startTime;
unsigned long deltaTime;
int speaking = 0;
// A0: INPUT is the default pin mode. No config required
pinMode(buttonPin, INPUT_PULLUP);
pinMode(ledPin, OUTPUT);
Particle.variable("speaking", speaking);
void tabelle2() {
int summe = 0;
double min = wave[0];
double max = wave[0];
for (int i = 0; i < recLength; i++) {
summe = summe + wave[i];
if (wave[i] < min) {
min = wave[i];
if (wave[i] > max) {
max = wave[i];
double mittelwert = summe / recLength;
double delta = (max - min) / 2;
wave[i] = (wave[i] - mittelwert) / delta;
//Serial.println(wave[i], 8);
void apply_filter() {
int start = FILTER_MITTELWERT;
double filtered_value = 0;
for (int i = 0; i < 10; i++) {
filtered_value = 0;
if (i < FILTER_MITTELWERT + 1) continue;
for (int f = FILTER_MITTELWERT + 1; f < FILTER_COUNT; f++) {
filtered_value = filtered_value + wave[i] * filter_value[f];
for (int f = FILTER_MITTELWERT; f > 0; f--) {
wave[i] = filtered_value;
int tmp = 0;
tmp = analogRead(microphone);
if (tmp < 900) {
i--;
continue;
wave[i] = tmp;
tabelle2();
apply_filter();
delay(250);
void ifSomeoneWasTalkingSendEvent() {
double x = 0;
double sum = 0;
//we send the speaking event and return if someone talks
//if no one talks, we already know that if someone was talking before, we send the stopped speaking event!
for(int i = 0; i < recLength; i++) {
x = (wave[i]);
if(x < 0) x = x * -1;
sum += x;
double mean = sum / recLength;
Serial.printf("Mean: %f\n", mean);
if(speaking == 0) {
if(mean > 0.23) {
Particle.publish("speaking", "true");
speaking = 1;
delay(750);
return;
if(speaking == 1) {
speaking = 0;
Particle.publish("speaking", "false");
delay(750);
now its blinking fast blue, and sometimes a red light appears.
is something wrong with the code??
the only way to get it running now again is to use particle dfu and flash tinker
