Hi all,
I’m try to forward the device name, using a webhook to thingsboard. The device name is send by the Argon which it got earlier using the cloud. (Particle.subscribe("particle/device/name", handler);)
It all works fine. The data is correct on the Argon and also arrives correct in the cloud/event.
This is my data json file from the argon code:
String payload = "{";
payload += "\"devName\":"; payload += devName_S;
payload += "}";
Event in the webhook:
"name": "Webhook",
"data": "{\"devName\":Argon64002}",
"ttl": 60,
"published_at": "2019-05-08T15:52:00.560Z",
"coreid": "XXXXXXXXXXXXXX"
Error response in the webhook:
HTTP/1.1 500
X-Content-Type-Options: nosniff
X-XSS-Protection: 1; mode=block
Cache-Control: no-cache, no-store, max-age=0, must-revalidate
Pragma: no-cache
Expires: 0
Content-Type: application/json;charset=UTF-8
Transfer-Encoding: chunked
Date: Wed, 08 May 2019 15:52:01 GMT
{"cause":null,"stackTrace":[{"methodName":"validateDataImpl","fileName":"DeviceServiceImpl.java","lineNumber":376,"className":"org.thingsboard.server.dao.device.DeviceServiceImpl$2","nativeMethod":false},{"methodName":"validateDataImpl","fileName":"DeviceServiceImpl.java","lineNumber":348,"className":"org.thingsboard.server.dao.device.DeviceServiceImpl$2","nativeMethod":false},{"methodName":"validate","fileName":"DataValidator.java","lineNumber":56,"className":"org.thingsboard.server.dao.service.DataValidator","nativeMethod":false}, **... and a lot more**
Data in thingsboard from the data converter:
and also the json format I want to send using the webhook:
"devName": "{{{devName}}}"
I have no Idea why there is no data send. If I change the devName to the temperature I also want to send, everything is working as expected…
Any hints?
Regards, Tim
