after updating particle-cli, my CLI is now at version 3.10.10… it was updated as global and using sudo
I’m getting error:
No such command 'library init'
I can create projects… just not libraries.
anyone else have a problem using init with the new libraries CLI tool?
That's rather surprising
AFAIK the most recent version is 1.19.2
And isn't it particle library create <libName>?
C:\Users>particle library --help
Usage: library <command>
Commands:
add Adds a library to the current project
create Creates a new library in the specified or current directory
copy Copies a library to the current project
view View details about a library
list Lists libraries available
migrate Migrates a local library from v1 to v2 format
search Searches available libraries
upload Uploads a private version of a library
publish Publishes a private library, making it public
Global Options:
-v, --verbose Increases how much logging to display [count]
-q, --quiet Decreases how much logging to display [count]
sorry, wrong paste... that was my npm version (I checked that too).
/usr/local/lib
└── particle-cli@1.19.2
I was referring to Step 2. of the uber library example on github.
Similar issues using create but slightly different error:
A name parameter is required to create a storage
the particle library list command works, returning my libraries as well as those published:
results:
My Libraries
DailyTimerSpark 0.1.3 38 Library that allow you to create daily timers
LiquidCrystal_I2C_Spark 1.1.0 816 LiquidCrystal_I2C ported for Spark Core
Sunrise 0.1.7 44 Sunrise/Sunset Time ported for Spark Core
Community Libraries
InternetButton 0.1.11 [official] 7660 Functions to make the Internet Button easy to use! If you have an original SparkButton, make sure to use begin(1)
AssetTracker 0.0.5 [official] 1196 Functions to make the Asset Tracker for Electron easy to use!
RelayShield 0.0.6 [official] 783 Functions to make the Photon Relay Shield even easier!
PowerShield 0.0.5 [official] 576 Library to support the fuel guage on the Power Shield
MakerKit 1.2.0 [official] 66 A library with examples for each Particle Maker Kit tutorial.
neopixel 0.0.13 [verified] 9125 An Implementation of Adafruit's NeoPixel Library for the Spark Core, Particle Photon, P1, Electron and RedBear Duo
OneWire 2.0.1 [verified] 5003 Dallas 1-Wire protocol with support for DS18B20, DS1820, DS1822
Serial_LCD_SparkFun 0.0.1 [verified] 285 A port of the serLCD library for the 16x2 LCD. Connect the LCD's RX to the Particle's TX, and print to Serial1
blynk 0.4.5 6182 Build a smartphone app for your project in minutes!
HttpClient 0.0.5 5280 A work in progress Http Client Library for the Spark Core and Arduino.
Press ENTER for next page, CTRL-C to exit.
My bad.
The <libName> either needs a --name before or CLI will ask for it.
Indeed, you are correct sir. I tried a bunch of variants of that, exactly.
JimMacbookPro:testlib james$ particle library --name test1 create
JimMacbookPro:testlib james$ particle library create --name testing
Below is the help for library create, but in a nutshell, if you only specify particle(-cli) library create, it should ask you for the library name, version and author. If you provide those parameters like particle library create --name dummyLibrary --version 1.0.0 --author dummyAuthor then it should create the template files for the library in the current directory.
If it doesn’t do that… then something is broken somewhere!
This is what it looks like on my windows box running v1.19.2 of the particle cli. I’m running node.js 6.9.5 if that matters.
Usage: library create [options]
Global Options:
Options:
--name The name of the library to create.
--version The initial version of the library to create.
--author The author of the library.
Seriously broken... yes.
I guess someone is going to tell me to do a reinstall, next.
Anyone else capable of doing this on a Mac before I go through all that?
So, i uninstalled/reinstalled particle-cli.... no success.
anyone have any recommendations? Again, I am on a mac here.
I am getting an error regarding the minimatch module:
$ sudo npm install -g particle-cli
npm WARN deprecated minimatch@2.0.10: Please update to minimatch 3.0.2 or higher to avoid a RegExp DoS issue
npm WARN excluding symbolic link test/server/static/ie8-polyfill.js -> ../../../ie8-polyfill.js
npm WARN deprecated node-uuid@1.4.7: use uuid module instead
/usr/local/bin/particle -> /usr/local/lib/node_modules/particle-cli/bin/particle.js
/usr/local/lib
JimMacbookPro:testlib james$ sudo npm list minimatch
/Users/james
└── (empty)
npm ERR! code 1
Odd. I got basically the same output as pfeerick when I tried it on the Mac:
$ mkdir testlib
$ cd testlib/
? Enter a name for your library: testlib
? Enter a version for your library: 0.0.1
? Who is the author of your library: rickkas7@rickkas7.com
create library.properties
create README.md
create LICENSE
create src/testlib.cpp
create src/testlib.h
create examples/usage/usage.ino
$ particle --version
1.19.2
hmmmm… do you also get the deprecation warning for minimatch when updating particle-cli?
Maybe I have some conflicting dependancies in npm. It looks like particle-cli has dependancies with different versions of minimatch. Then again, maybe none of this matters!
Can you npm list -g minimatch for me?
> 08:18:23 $ npm list -g minimatch
/usr/local/lib
├─┬ ionic@2.0.0
│ ├─┬ gulp@3.8.8
│ │ ├─┬ liftoff@0.12.1
│ │ │ └─┬ findup-sync@0.1.3
│ │ │ └─┬ glob@3.2.11
│ │ │ └── minimatch@0.3.0
│ │ └─┬ vinyl-fs@0.3.14
│ │ ├─┬ glob-stream@3.1.18
│ │ │ └── minimatch@2.0.10
│ │ └─┬ glob-watcher@0.0.6
│ │ └─┬ gaze@0.5.2
│ │ └─┬ globule@0.1.0
│ │ └── minimatch@0.2.14
│ ├─┬ prompt@0.2.12
│ │ └─┬ utile@0.2.1
│ │ └─┬ rimraf@2.5.4
│ │ └─┬ glob@7.0.5
│ │ └── minimatch@3.0.3
│ └─┬ unzip@0.1.9
│ └─┬ fstream@0.1.31
│ └─┬ rimraf@2.5.4
│ └─┬ glob@7.0.5
├── minimatch@3.0.3
├─┬ npm@3.10.10
│ ├─┬ fstream-npm@1.2.0
│ │ └─┬ fstream-ignore@1.0.5
│ ├─┬ glob@7.1.0
│ ├─┬ init-package-json@1.9.4
│ │ └─┬ glob@6.0.4
│ ├─┬ node-gyp@3.4.0
│ └─┬ read-package-json@2.0.4
│ └─┬ glob@6.0.4
├─┬ particle-cli@1.19.2
│ ├─┬ glob@4.5.3
│ ├─┬ serialport@4.0.7
│ │ └─┬ node-pre-gyp@0.6.32
│ │ ├─┬ rimraf@2.5.4
│ │ │ └─┬ glob@7.1.1
│ │ │ └── minimatch@3.0.3
│ │ └─┬ tar-pack@3.3.0
│ └─┬ yeoman-generator@0.24.1
│ ├─┬ glob@7.1.1
│ ├─┬ mem-fs-editor@2.3.0
│ │ ├─┬ glob@7.1.1
│ │ └─┬ multimatch@2.1.0
│ ├─┬ rimraf@2.5.4
│ │ └─┬ glob@7.1.1
│ └─┬ shelljs@0.7.6
│ └─┬ glob@7.1.1
└─┬ reverse-proxy-js@0.5.4
└─┬ forever@0.15.2
├─┬ forever-monitor@1.6.0
│ ├─┬ chokidar@1.6.0
│ │ ├─┬ fsevents@1.0.14
│ │ │ └─┬ node-pre-gyp@0.6.29
│ │ │ └─┬ rimraf@2.5.3
│ │ │ └─┬ glob@7.0.5
│ │ │ └── minimatch@3.0.2
│ │ └─┬ readdirp@2.1.0
└─┬ utile@0.2.1
└─┬ rimraf@2.5.4
└─┬ glob@7.0.5
└── minimatch@3.0.2
my try as you did above:
> 08:12:08 $ mkdir testlib
> 08:12:41 $ cd testlib/
> 08:12:50 $ particle library create
> 08:13:02 $
Everyone gets the minimatch warning; that shouldn’t be a problem. Your CLI is otherwise working, like you can do particle list and things like that, right?
yeah, it works fine, even with the project create tool:
> 08:33:00 $ particle library create
> 08:33:05 $
> 08:33:07 $ particle project create
What would you like to call your project? [myproject]: my-proj
Would you like to create your project in the default project directory? [Y/n]: > 08:33:32 $
> 08:33:34 $
> 08:33:51 $ particle library create --name my-test-lib
> 08:34:07 $
> 08:34:10 $
verbose error log:
> 09:00:32 $ particle library create -v
{ AssertionError: A name parameter is required to create a storage
at new Storage (/usr/local/lib/node_modules/particle-cli/node_modules/yeoman-generator/lib/util/storage.js:24:3)
at LibraryInitGenerator.Base._getStorage (/usr/local/lib/node_modules/particle-cli/node_modules/yeoman-generator/lib/base.js:673:10)
at LibraryInitGenerator.Base (/usr/local/lib/node_modules/particle-cli/node_modules/yeoman-generator/lib/base.js:157:22)
at LibraryInitGenerator._class (/usr/local/lib/node_modules/particle-cli/node_modules/particle-library-manager/dist/libinit.js:91:108)
at new LibraryInitGenerator (/usr/local/lib/node_modules/particle-cli/node_modules/particle-library-manager/dist/libinit.js:299:143)
at Environment.instantiate (/usr/local/lib/node_modules/particle-cli/node_modules/yeoman-environment/lib/environment.js:336:10)
at Environment.create (/usr/local/lib/node_modules/particle-cli/node_modules/yeoman-environment/lib/environment.js:313:15)
at Environment.run (/usr/local/lib/node_modules/particle-cli/node_modules/yeoman-environment/lib/environment.js:372:24)
at /usr/local/lib/node_modules/particle-cli/node_modules/particle-commands/dist/cmd/library_init.js:97:20
at /usr/local/lib/node_modules/particle-cli/node_modules/es6-promisify/dist/promisify.js:75:41
actual: '',
expected: true,
operator: '==',
message: 'A name parameter is required to create a storage',
generatedMessage: false } [ 'AssertionError: A name parameter is required to create a storage',
' at new Storage (/usr/local/lib/node_modules/particle-cli/node_modules/yeoman-generator/lib/util/storage.js:24:3)',
' at LibraryInitGenerator.Base._getStorage (/usr/local/lib/node_modules/particle-cli/node_modules/yeoman-generator/lib/base.js:673:10)',
' at LibraryInitGenerator.Base (/usr/local/lib/node_modules/particle-cli/node_modules/yeoman-generator/lib/base.js:157:22)',
' at LibraryInitGenerator._class (/usr/local/lib/node_modules/particle-cli/node_modules/particle-library-manager/dist/libinit.js:91:108)',
' at new LibraryInitGenerator (/usr/local/lib/node_modules/particle-cli/node_modules/particle-library-manager/dist/libinit.js:299:143)',
' at Environment.instantiate (/usr/local/lib/node_modules/particle-cli/node_modules/yeoman-environment/lib/environment.js:336:10)',
' at Environment.create (/usr/local/lib/node_modules/particle-cli/node_modules/yeoman-environment/lib/environment.js:313:15)',
' at Environment.run (/usr/local/lib/node_modules/particle-cli/node_modules/yeoman-environment/lib/environment.js:372:24)',
' at /usr/local/lib/node_modules/particle-cli/node_modules/particle-commands/dist/cmd/library_init.js:97:20',
' at /usr/local/lib/node_modules/particle-cli/node_modules/es6-promisify/dist/promisify.js:75:41' ]
> 09:00:40 $
@kennethlimcp ? @Moors7 ?
any suggestions here?
@BulldogLowell i wonder if it’s an issue for your specific linux distribution. Can you share more information?
I get this:
KENMBP:lib kennethlimcp$ p library create
? Enter a name for your library: kennethlimcp
? Who is the author of your library: me!
create README.md
create LICENSE
create src/kennethlimcp.cpp
create src/kennethlimcp.h
@kennethlimcp He’s on a Mac
But yes, some more details like the version might be handy
macOS Sierra 10.12.3
/usr/local/lib
dev: 1.7.4
I’ve uninstalled and reinstalled, etc…
@BulldogLowell, i wonder if particle-cli is unable to create the files in the directory that you are in.
Did you:
$ mkdir testlib (in the desktop)
$ cd test lib
well,
project create works.... but library create... nope.
19:39:30Mon Feb 06 $ mkdir testlib
19:39:43Mon Feb 06 $ cd testlib/
19:39:49Mon Feb 06 $ particle library create
19:40:02Mon Feb 06 $
