Hi all,
I have a problem with random numbers coming from a HX711 ADC.
See “capture” image:
I am generating this output form the following code:
scale.set_scale(calibration_factor); //Adjust to this calibration factor
Serial.print("RAW ");
Serial.print(scale.read());
Serial.print(" one reading:\t");
Serial.println(scale.get_units(), 10);
delay(200);
For some reason, the scale.read(); function is extremely volatile, and returns -1 (which is false) nearly 50% of the time.
For (scale.get_units(), 10);, the correct reading is -13kg in this case, but for some reason I get a random 52.47kg (without touching anything). I am have the same issue with other systems in the field, but there the problem seems to be much worse (only giving a correct reading 10% of the time).
Also, here does seem to be other incorrect numbers showing up every now and then, see below:
To add some more information to help problem solve this issue, I then placed a weight on the scales to change the nominal. With the following result:
I have been using a particle Boron to communicate with a HX711 ADC through pins:
HX711ADC scale(A1, A0);
Has anybody got any ideas?
Thanks in advance, Micheál.
