Rundown:
- have updated from command line (particle update)
- uploaded code that from cmd, which is tested and functioning on another boron (particle flash --usb boron_firmware_############.ino, receive “flash success!”)
- device booted, flashed green for a minute, never runs my code as far as I can tell but did connect to the cloud before going in to breathing cyan before going to breathing magenta (safe mode?)
- seemingly infinite loop of breathing magenta and then seemingly turning off again and random looking intervals
doesn’t appear to be any report on what version “particle update” established, but is the same process I used on the duplicate device. My firmware is 1.3.0-rc.1.
is it…doing a cloud update? Or stuck in a loop? I’m just letting it run at the moment but it’s been back and forth with magenta and off for maybe 15-20 minutes now…
** edit, as I’m typing this it swung back to a single round of cloud connection and posted a “spark/flash/status (failed)” event. Happens I suppose…but how do I…unfail it?
