Hi all,
any tutorial for asset tracker GPS location and other sensor monitor? i used the example in the library for the location but it seems there is a problem i still got no location.
thank you
Hi all,
thank you
Have you used the pimped AT library
https://github.com/rickkas7/AssetTrackerRK (also available on Web IDE)
Have you got a fix?
Is your AT inside or outside, with or without external GPS antenna?
How long did you let the device run to acquire a fix?
