I’ve ported our code from spark.js to particle-api-js.
After Opening the EventStream (‘mine’, or all events) the eventstream stops working after a few seconds up to a few minutes. No ‘error’ or ‘end’ Event is issued for this.
Using the old Spark.JSLibary this problem occurs after a few days or so
server.getEventStream({deviceId: 'mine', auth: token}).then(function(stream) {
eventStream = stream;
stream.on('event', function(data) {
//logger.info({ev: data},'EVENT');
mainEvent(data);
stream.on('error',function (err) {
logger.error({e: err}, 'Stream has processsed error')
if (!goingdown) {
//ReOpen Stream, the Server is not Going Down!
logger.info("Stream will re-opening in 5 seconds...");
setTimeout(loginToSpark, 5 * 1000);
stream.on('end', function () {
logger.warn('EventStream was Closed, or forced to close!');
if (!goingdown) {
if (started !== undefined) started();
Maybe the old Libary can solve this problem ?
