getEventStream dies after few days
I’m trying to hold a persistent connection to the particle cloud so that I can receive updates to my backend based on publishes from the P1s I have in the field. Everything works great, but after a few days the connection is lost and I no longer receive any signals despite the server functioning normal. I tried to implement this examples, but it is still failing
https://github.com/spark/sparkjs/blob/master/examples/node/get-event-stream-forever.js
I am wondering if something is wrong with the code below, or if I’m missing another piece. Thanks!
var mysql = require('mysql');
var cluster = require('cluster');
var os = require('os');
var bunyan = require('bunyan');
var spark = require('spark');
var async = require('async');
var net = require('net');
var config = require('./api/config.js');
var log = bunyan.createLogger({ name: 'services' });
var pool = mysql.createPoolCluster();
if (cluster.isMaster) {
  pool.add(config.dbPoolCreds);
  var numWorkers = os.cpus().length;
  log.info('Master cluster setting up ' + numWorkers + ' workers...');
  for (var i = 0; i < numWorkers; i++) {
    var worker = cluster.fork();
  spark.login(config.particleLogin, function(err, body) {
    if (err) {
      log.error(err);
    log.info({ spark: body });
  var openStream = function() {
    var req = spark.getEventStream(false, 'mine', function(data) {
      log.warn(data);
      worker.send(data);
    req.on('end', function() {
      log.warn('Particle server ended!  re-opening in 3 seconds...');
      setTimeout(openStream, 3 * 1000);
  spark.on('login', function() {
    openStream();
  cluster.on('online', function(worker) {
    log.info('Worker ' + worker.process.pid + ' is online');
  cluster.on('exit', function(worker, code, signal) {
    log.info('Worker ' + worker.process.pid + ' died with code: ' + code + ', and signal: ' + signal);
    log.info('Starting a new worker');
    cluster.fork();
} else {
  process.on('message', function(data) {
    if (!data) {
      return;
    log.warn(data);
Weird…
Are you able to see if the the openStream function is called each time a message is published to see what’s not triggering/running?
Not seeing anything really, ideally the openStream function only gets called with the particle login. It definitely does when I restart the server, but somehow it’s not being called when there is a reset from particle’s end.
This should kick in when that scenario happens… Let’s see what the other Javascript gurus have to say :slight_smile:
