Looking at the source code, it’s not clear to me where these prices are coming from. I was hoping to find an API in the HTML source that the data may be coming from but I suppose this is being done server side and the HTML is displaying the data from a database?
Anyhow, would it be possible to write a function using HttpClient that parses the response for the different divs (e.g. price wkm2201) and returns the price as a string/int?
If you are looking to extract the data from the webpage, it is fairly straightforward.
What you do is ‘Get’ the page, and then search it for a unique phrase that is always the same.
In this case there is “price wkm2201”.
That will give you the starting point of that phrase. Then you add the number of characters to count from the start of that phrase to where the actual data the you want starts, and you end with another search (in this case , to where the end of the desired data.
