P1 external flash API's stopped working all of a sudden. What am I doing wrong?
Hello,
The following piece of code was working fine until now. I am unable to read/write anything into external flash.
#include "flashee-eeprom.h"
using namespace Flashee;
FATFS fs;
FRESULT result;
const char * fileName = "firmware.txt";
const char * message = "Hello!";
    //create memory region
    while(!Serial.available()){
      Particle.process();
    result = Devices::createFATRegion(0, 4096*256, &fs);
    if(result != FR_OK){
        Serial.println("Error mounting file system");
        return;
    }else{
        Serial.println("File system success");
    //FILE ATTRIBUTES
    FIL fil;
    FRESULT fr;
    UINT dw;
    /*Delete the file if it exits already*/
    fr = f_unlink(fileName);
    ((fr = f_open(&fil, fileName, FA_WRITE|FA_CREATE_NEW)) == FR_OK) &&
    ((fr = f_write(&fil, (const char *)message, strlen(message)+1, &dw)) == FR_OK) &&
    ((fr = f_close(&fil))==FR_OK);
    Serial.println("Created a file");
    Serial.printf("write: %d\n" , dw);
    char buf[128];
    memset(buf, 0, sizeof(buf));
    ((fr = f_open(&fil, fileName, FA_READ|FA_OPEN_EXISTING)) == FR_OK) &&
    ((fr = f_read(&fil, buf, sizeof(buf), &dw)) == FR_OK) &&
    ((fr = f_close(&fil)) == FR_OK);
    Serial.printf("Read: %d\n" , dw);
    Serial.printf("File contents: %s\n", buf);
Output:
File system success
Created a file
write: 0
Read: 0
File contents:
I am unable to read or write. Is my external flash damaged?
Dheeraj
Hmm… @peekay123 you have some idea?
I am not familiar but does dw get a value after the f_write()?
Also, the statement fr = f_open == FR_OK… Wouldn’t that return the evaluation result, changing what fr is referenced to?
@dheerajdake
I agree with @kennethlimcp that this will most likely not work. I am not even sure what the purpose of the statement is as any returned error will be wiped unless it is the last statement. I would be more granular in order to handle errors more effectively:
fr = f_open(&fil, fileName, FA_WRITE|FA_CREATE_NEW);
if (fr != FR_OK) {
  Serial.printf("ERROR opening file! (error %d)", fr);
  while(1) Particle.process();  // Stop the application by looping forever!
fr  = f_write(&fil, (const char *)message, strlen(message)+1, &dw));
if (fr != FR_OK)  {
  Serial.printf("ERROR writing to file! (error %d)", fr);
fr = f_close(&fil);
if (fr != FR_OK)  {
  Serial.printf("ERROR closing file! (error %d)", fr);
In the above example, the application will stop and call `Particle.process()` to ensure OTA can continue to work.  You may want to handle the errors differently.  Exception (error) handling is crucial in any application.
Yes, dw returns the number of bytes written to the file. I have seen that. This line
((fr = f_open(&fil, fileName, FA_WRITE|FA_CREATE_NEW)) == FR_OK);
Assigns a value to fr and if it is equal to FR_OK, the condition is true.
@peekay123
This syntax is from the example in here. The condition checks are guaranteed after every statement. Not just the last line.
I have verified the conditions checks already by reformatting the syntax as
((fr = f_write(&fil, (const char *)message, strlen(message)+1, &dw)) == FR_OK);
All of them said fr == FR_OK. I am very sure that this worked before.
Dheeraj
@dheerajdake, I have no doubt they work. It’s just that the code isn’t written for good exception handling. Have you tried replacing your string declarations for const char * to:
const char fileName[] = "firmware.txt";
const char message[] = "Hello!";
The array name is also the pointer to the array.
Yes I did. Still the same output.
Pinging @rickkas7
Unfortunately, I don’t have answer why it stopped working. I ran this code, on a P1 and it worked fine:
#include "Particle.h"
// Uses:
// https://github.com/m-mcgowan/spark-flashee-eeprom
// Add to project.properties:
// dependencies.flashee-eeprom=0.1.8
FATFS fs;
void testFs();
	delay(5000);
	testFs();
void testFs() {
	FRESULT result = Devices::createFATRegion(0, 4096*256, &fs);
		return;
	}else{
	//FILE ATTRIBUTES
	FIL fil;
	FRESULT fr;
	UINT dw;
	if (fr != FR_OK) {
		return;
	fr  = f_write(&fil, (const char *)message, strlen(message)+1, &dw);
	if (fr != FR_OK)  {
		return;
	fr = f_close(&fil);
	if (fr != FR_OK)  {
		return;
	char buf[128];
This was the serial output:
File system success
Created a file
write: 7
Read: 7
File contents: Hello!
Tested on a P1 (Sparkfun Redboard) with 0.6.2.
That’s the same code. How do I know if my external flash is damaged?
I’d try adding the 4th parameter to the Devices::createFATRegion call, FORMAT_CMD_FORMAT. The default is to format the device as a FAT volume if it looks invalid, but maybe your flash is almost but not quite valid. Perhaps formatting it will help.
