Is it possible to update Firmware over the air? Not user part but system parts (aka modules). If so please explain.
Instructions on OTA updating system firmware: https://github.com/spark/firmware/releases/tag/v0.4.1
I’ll reproduce it here so that we have a searchable record:
The system firmware update can be applied OTA or via DFU.
OTA with the particle-cli
Here’s the steps to flash using particle-cli
- download
system-part1.binandsystem-part2.bin - put the device (the photon) in safe mode: hold setup, then tap reset, and release setup when the LED blinks magenta
- the device will connect to the cloud, and breathe cyan (in 0.4.2 or later, it will breathe magenta, indicating safe mode)
- run
particle flash <photonid> system-part1.bin - when the device reboots, put the device again in safe mode
- run
particle flash <photonid> system-part2.bin
Flashing locally with DFU
It’s also possible to flash the firmware update using DFU:
- download
system-part1.binandsystem-part2.bin - put your photon in DFU mode - hold setup, tap reset, and release setup when the LED blinks yellow.
- run
dfu-util -d 2b04:d006 -a 0 -s 0x8020000 -D system_part1.bin - run
dfu-util -d 2b04:d006 -a 0 -s 0x8060000 -D system_part2.bin
