I need to update a couple of Electrons in the field and I thought I’d download the OS firmware first so I can flash it via USB. When I downloaded and reviewed the files (1.1.1 and 1.2.1), they all include “+debug”. Are these the appropriate files to use when I have no plans to use the debugger. I apologize for asking a simple question without doing more research, but I’m in a rush to get things done.
Looks like you are in the right track and just have to follow the DeviceOS thread for release/production versions.
As for the debugs flags some are just there so if a developer or Particle team wants to enable DEBUG messages while running code they can do it in a easy way.
Gen2 system binaries always came as debug versions when downloaded from the GitHub repo - so they are safe to use but may be a bit verbose when you initialise a log handler.
Now, it’s just more obvious due to the naming
If your devices receive a Safe Mode Healer update you usually don’t get the debug versions.
