Probably not a hardware defect. Others have been having this problem with certain Xenons. As suggested by @avtolstoy, you can flash some special diagnostic binaries to output debugging information on Serial1. However, of the 2 or 3 logs others have already posted, the failure looks to be the same. Something about RTC/jitter correction. You may still want confirmation from someone at Particle but see the following post:
