Does anyone have any recommendations for an on device (Boron) Database or Key Value storage solution for a large (30K+) number of values?
Ideally it will be persisted to an external flash chip via SpiffsParticleRK
In terms of existing libraries I have seen SQLITE solutions for the ESP8266 (uses 20kb of ram) and Key value solutions for arduino via SD (won’t compile in particle). So it seems do-able I just wanted to see if anyone had any recommendations before I go down the rabbit hole of converting one of these libraries.
