How to store large datasets in external flash in P1?
Hello Particle,
I want to store the samples from a analogPin every millisecond. The analog pin resolution is 12 bits, values ranging from 0-4095 so 2 bytes. The external flash size is 1 MB which is 1,000,000 bytes. Hence I should be able to store 500,000 short integers.
How can I use flashee library to do this? I tried experimenting with circular buffer API’s but I ended up with red flashes.
Is there a way to write to flash on the go, instead of specifying a struct and size and passing an address of it into the write() API?
Like FLASH.write(address, data); //where address can range from 0 - 1000000
On P1, with flash->write(addr, value), I am able to write and read from the address 129000. When I choose the address as 130000, the write/read fails.
@dheerajdake I haven’t used the EEPROM yet although I will try to take a stab at a solution.
Referring to: https://github.com/m-mcgowan/spark-flashee-eeprom
384 pages @ 4096 bytes each are available in the EEPROM. That’s 1,048,576 bytes.
Two pieces of information to consider from the readme:
  • The spark external flash has 384 pages, each 4096 bytes in size and is managed as the device provided via the Devices::userFlash() method. Rather than hard-code these page count and page size constants, you can make the code more flexible for future changes by using: Devices::userFlash().pageSize() and Devices::userFlash().pageCount()
  • At present, the maximum contiguous area that the Wear Leveling and Address Erase schemes can occupy is 1MB (256 pages). This is to keep runtime memory overhead to a minimum.
A workaround is to create 2 devices as shown below in separate regions.
    FlashDevice* eeprom = Devices::createAddressErase(0, 256*4096);
    CircularBuffer* logBuffer = Devices::createCircularBuffer(256*4096, 384*4096);
My thinking is that the reason you are getting that error is because your read/write may fall along a page boundary when you create your device.
Each page can store 4096 bytes/2 bytes = 2048 short ints.
The following creates a buffer between page 256 and 384 (~0.5 MB). Its just for demonstration but expand it for your own application.
CircularBuffer* buffer = Devices::createCircularBuffer(4096256, 4096384);
When you read and write, use pointers and increment/decrement the address. Something like below:
short data;
short* ptr;
ptr = &data;
bool success = buffer->write(ptr++, sizeof(data));
I’ll edit the post later to make it more clear.
I think
FlashDevice* eeprom = Devices::createAddressErase(0, 256*4096); //-- 1
does the same thing as
FlashDevice *eeprom = Devices::createDefaultStorage(); // – 2
Call 1, is allocating 0 to 1,048,576 bytes. I believe I should be able to write and read from any byte within that range. But I was only able to read/write between 0-129,000. It fails after 130,000.
Here is my code compiled and flashed using the particle web ide:
#include "flashee-eeprom/flashee-eeprom.h"
using namespace Flashee;
#define ADDRESS 100000
#define VAL 2179
FlashDevice* flash;
        flash = Devices::createAddressErase(0, 256*4096);
        flash->write(VAL, ADDRESS);
    short a;
    flash->read(a, ADDRESS);
    Serial.println(a);
    delay(200);
The output is as expected for ADDRESS<=129000. The output is 0 for ADDRESS greater than 130000. I am not sure why. This isn’t EEPROM. It’s the external flash.
Dheeraj
Try:
flash = Devices::createAddressErase(0, 256);
I think the README is wrong.
