Okhttp is unresolved in Android SDK
Calling init() in my kotlin app crashes the app immediately. This is the only particle function I call so far, to test I have all the dependencies. I’m working in kotlin.
I followed the stack trace to the library, where okhttp is unresolved . It is highlighted red, as is every http parsing function in the library itself. Is the Android SDK setup page up to date? The repo hasn’t been touched in quite a while.
Reverting to 0.5.1 has the app working, but I would really like to use the newest SDK.
My build.gradle file:
plugins {
    id 'com.android.application'
    id 'kotlin-android'
    id 'com.google.secrets_gradle_plugin' version '0.5'
android {
    compileSdkVersion 30
    buildToolsVersion "30.0.3"
    defaultConfig {
        applicationId "com.masterandroid.meg"
        minSdkVersion 22
        targetSdkVersion 30
        versionCode 1
        versionName "1.0"
        testInstrumentationRunner "androidx.test.runner.AndroidJUnitRunner"
    buildTypes {
        release {
            minifyEnabled false
            proguardFiles getDefaultProguardFile('proguard-android-optimize.txt'), 'proguard-rules.pro'
    compileOptions {
        sourceCompatibility JavaVersion.VERSION_1_8
        targetCompatibility JavaVersion.VERSION_1_8
    kotlinOptions {
        jvmTarget = '1.8'
dependencies {
    implementation 'com.squareup.okhttp3:okhttp:4.9.0'
    implementation 'io.particle:cloudsdk:0.5.1'
    implementation "org.jetbrains.kotlin:kotlin-stdlib:$kotlin_version"
    implementation 'androidx.core:core-ktx:1.6.0'
    implementation 'androidx.appcompat:appcompat:1.3.1'
    implementation 'com.google.android.material:material:1.4.0'
    implementation 'androidx.constraintlayout:constraintlayout:2.1.1'
    implementation 'com.google.android.gms:play-services-maps:17.0.1'
    testImplementation 'junit:junit:4.13.2'
    androidTestImplementation 'androidx.test.ext:junit:1.1.3'
    androidTestImplementation 'androidx.test.espresso:espresso-core:3.4.0'
    implementation("org.jetbrains.kotlinx:kotlinx-coroutines-android:1.3.9")
    implementation 'androidx.legacy:legacy-support-v4:1.0.0'
    implementation 'androidx.localbroadcastmanager:localbroadcastmanager:1.0.0'
There are definitely some dependencies that aren’t really needed, I just included everything hoping I would eventually include the required set. I was able to add okhttp3 and reference the broken SDK functions in my main activity just to test if the squareup repo was broken.
My android manifest file:
<?xml version="1.0" encoding="utf-8"?>
<manifest xmlns:android="http://schemas.android.com/apk/res/android"
    package="com.masterandroid.meg">
    <uses-permission android:name="android.permission.ACCESS_FINE_LOCATION"/>
    <uses-permission android:name="android.permission.WRITE_EXTERNAL_STORAGE" />
    <uses-permission android:name="android.permission.INTERNET"/>
    <application
        android:allowBackup="true"
        android:icon="@mipmap/ic_launcher"
        android:label="@string/app_name"
        android:roundIcon="@mipmap/ic_launcher_round"
        android:supportsRtl="true"
        android:theme="@style/Theme.MEG">
        <activity android:name=".MainActivity">
            <intent-filter>
                <action android:name="android.intent.action.MAIN" />
                <category android:name="android.intent.category.LAUNCHER" />
            </intent-filter>
        </activity>
        <uses-library
            android:name="org.apache.http.legacy"
            android:required="false" />
        <meta-data
            android:name="com.google.android.gms.version"
            android:value="@integer/google_play_services_version" />
        <meta-data
            android:name="com.google.android.geo.API_KEY"
            android:value="${MAPS_API_KEY}" />
    </application>
</manifest>
I included the permissions that worked last time I needed the particle API, but they didn’t help with the latest release. I went back to 1.0.0 and the issue remains.
Any ideas what could be going wrong? Thanks everybody!
Could you please provide the errors you’re getting.
The error is below. Android Studio offered to decompile the ParticleCloudSDK library when I click on the error message “at io.particle.android.sdk.cloud.ParticleCloudSDK.init(ParticleCloudSDK.java:27)”.
As I said before, everything that has to do with okhttp is unresolveable.
The import line in the library is line 7, import com.squareup.okhttp.HttpUrl; Hovering over the red okhttp text gives the message cannot resolve symbol 'okhttp'.
2021-10-12 23:24:19.118 5212-5212/com.masterandroid.sdktest E/AndroidRuntime: FATAL EXCEPTION: main
    Process: com.masterandroid.sdktest, PID: 5212
    java.lang.NoClassDefFoundError: Failed resolution of: Lcom/squareup/okhttp/HttpUrl;
        at io.particle.android.sdk.cloud.ParticleCloudSDK.initWithInstanceCheck(ParticleCloudSDK.java:48)
        at com.masterandroid.sdktest.MainActivity.onCreate(MainActivity.kt:11)
        at android.app.Activity.performCreate(Activity.java:7963)
        at android.app.Activity.performCreate(Activity.java:7952)
        at android.app.Instrumentation.callActivityOnCreate(Instrumentation.java:1307)
        at android.app.ActivityThread.performLaunchActivity(ActivityThread.java:3629)
        at android.app.ActivityThread.handleLaunchActivity(ActivityThread.java:3806)
        at android.app.servertransaction.LaunchActivityItem.execute(LaunchActivityItem.java:83)
        at android.app.servertransaction.TransactionExecutor.executeCallbacks(TransactionExecutor.java:135)
        at android.app.servertransaction.TransactionExecutor.execute(TransactionExecutor.java:95)
        at android.app.ActivityThread$H.handleMessage(ActivityThread.java:2267)
        at android.os.Handler.dispatchMessage(Handler.java:107)
        at android.os.Looper.loop(Looper.java:237)
        at android.app.ActivityThread.main(ActivityThread.java:8167)
        at java.lang.reflect.Method.invoke(Native Method)
        at com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run(RuntimeInit.java:496)
        at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:1100)
     Caused by: java.lang.ClassNotFoundException: Didn't find class "com.squareup.okhttp.HttpUrl" on path: DexPathList[[zip file "/data/app/com.masterandroid.sdktest-pV8Bo8Zv8vEHFD9yEicpyg==/base.apk"],nativeLibraryDirectories=[/data/app/com.masterandroid.sdktest-pV8Bo8Zv8vEHFD9yEicpyg==/lib/arm64, /system/lib64, /system/product/lib64]]
        at dalvik.system.BaseDexClassLoader.findClass(BaseDexClassLoader.java:196)
        at java.lang.ClassLoader.loadClass(ClassLoader.java:379)
        at java.lang.ClassLoader.loadClass(ClassLoader.java:312)
Replied below, thanks for taking a look!
