Hello,
I have to say, I’m a bit new on C++. My goal is to have a multi switch build which includes a OLED (SPI) display. The photon should read out the devices for a specific room from FHEM (Home Automation system) and display (and later toggle) the status of the devices. FHEM provides a simple JSON protocol which includes all devices in a list. This list I would like to turn into a list of (device)-objects to iterate through on the photon and then display the status scrollable on the display.
Now running the display and also present some values there I made already. But the challenge for me is to build the list of objects right out of the JSON list. The list contains currently also additional values which I will strip down later in the FHEM. My interest is currently only the NAME,Value and from the Attributes section the group.
As the PHOTON switch should be a generic build (later for multiple rooms) I would like to keep the code “stupid” and the objects should be get their definition out of the JSON.
I know, that there are already libraries out there, reading a json string, but I’m mainly failing in building the object structure out of it.
Can someone help my to get at least a point, where I can go by myself.
Thanks a lot.
Jens
This is the provided list from the Server:
"Arg":"TYPE=EIB:FILTER=room=Wohnzimmer",
"Results": [
"Name":"EIB_000c",
"Internals": {
"DEF": "000c",
"GROUP": "000c",
"LASTGROUP": "000c",
"LASTInputDev": "tul",
"MSGCNT": "158",
"NAME": "EIB_000c",
"NR": "31",
"RAWSTATE": "off",
"STATE": "off",
"TYPE": "EIB",
"tul_MSGCNT": "158",
"tul_RAWMSG": "Bf10dw000c00",
"tul_TIME": "2015-08-20 23:27:13"
"Readings": {
"state": { "Value":"off", "Time":"2015-08-20 23:27:13" }
"Attributes": {
"IODev": "tul",
"alias": "Szene Essen",
"fm_type": "lamp",
"group": "Licht,Szenen,Wohnzimmer",
"room": "Wohnzimmer,Favourites"
"Name":"EIB_000d",
"Internals": {
"DEF": "000d",
"GROUP": "000d",
"NAME": "EIB_000d",
"NR": "33",
"STATE": "off",
"TYPE": "EIB"
"Readings": {
"state": { "Value":"off", "Time":"2015-04-25 23:30:11" }
"Attributes": {
"IODev": "tul",
"alias": "Szene Fernsehen",
"fm_type": "lamp",
"group": "Szenen,Licht,Wohnzimmer",
"Name":"Esstisch",
"Internals": {
"DEF": "0004",
"GROUP": "0004",
"NAME": "Esstisch",
"NR": "42",
"STATE": "off",
"TYPE": "EIB"
"Readings": {
"state": { "Value":"off", "Time":"2015-04-25 21:50:15" }
"Attributes": {
"IODev": "tul",
"alias": "Esstisch",
"fm_type": "lamp",
"fp_Home": "8,323,1,,",
"group": "Wohnzimmer",
"Name":"Pfette",
"Internals": {
"DEF": "0003",
"GROUP": "0003",
"LASTGROUP": "0003",
"MSGCNT": "7",
"NAME": "Pfette",
"NR": "28",
"RAWSTATE": "on",
"STATE": "on",
"TYPE": "EIB",
"tul_MSGCNT": "7",
"tul_RAWMSG": "B11fbw000301",
"tul_TIME": "2015-08-20 22:59:33"
"Readings": {
"state": { "Value":"on", "Time":"2015-08-20 22:59:33" }
"Attributes": {
"IODev": "tul",
"alias": "Pfette",
"fm_type": "lamp",
"fp_Home": "224,240,1,,",
"group": "Wohnzimmer,Licht",
"room": "Wohnzimmer"
"Name":"Sky",
"Internals": {
"DEF": "000b",
"GROUP": "000b",
"LASTGROUP": "000b",
"MSGCNT": "14",
"NAME": "Sky",
"NR": "37",
"RAWSTATE": "off",
"STATE": "off",
"TYPE": "EIB",
"tul_MSGCNT": "14",
"tul_RAWMSG": "B11fbw000b00",
"tul_TIME": "2015-08-21 12:15:59"
"Readings": {
"state": { "Value":"off", "Time":"2015-08-21 12:15:59" }
"Attributes": {
"IODev": "tul",
"alias": "Sky",
"fm_type": "lamp",
"fp_Home": "286,390,1,,",
"group": "Licht,Wohnzimmer",
"Name":"Stehlampe",
"Internals": {
"DEF": "0002",
"GROUP": "0002",
"LASTGROUP": "0002",
"MSGCNT": "164",
"NAME": "Stehlampe",
"NR": "29",
"RAWSTATE": "on",
"STATE": "on",
"TYPE": "EIB",
"tul_MSGCNT": "164",
"tul_RAWMSG": "Bf10dw000201",
"tul_TIME": "2015-08-20 12:21:27"
"Readings": {
"state": { "Value":"on", "Time":"2015-08-20 12:21:27" }
"Attributes": {
"IODev": "tul",
"alias": "Stehlampe",
"fm_type": "lamp",
"fp_Home": "113,630,1,,",
"totalResultsReturned":6
