Full error is:
"C:\Users\chris\AppData\Local\particle\node-v5.4.1-windows-x64\lib\node_modules\npm\cli.js" "install" "particle-cli"
! npm ERR! node v5.4.1
! npm ERR! npm v3.3.10
! npm ERR! Callback called more than once.
! npm ERR!
! npm ERR! If you need help, you may report this error at:
! npm ERR! https://github.com/npm/npm/issues
! npm ERR! Please include the following file with any support request:
! npm ERR! C:\Users\chris\AppData\Local\particle\npm-debug.log
! Try running again with GODE_DEBUG=info to see more output.at makeError (C:\Users\chris\.vscode\extensions\particle.particle-vscode-core-1.0.0-alpha.6\node_modules\execa\index.js:174:9) at module.exports.Promise.all.then.arr (C:\Users\chris\.vscode\extensions\particle.particle-vscode-core-1.0.0-alpha.6\node_modules\execa\index.js:278:16) at <anonymous>
I have uninstalled and reinstalled the particle-vscode-core-1.0.0-alpha.6.vsix extension a couple of times, along with reboots. Do I need to install some Javascript/Node extensions to Visual Studio Code first?
Thanks in advance,
-CK
