I’m trying to get an Arduino 8x8 LED matrix going with my Spark and I feel that I know enough to be quite dangerous…
I’m starting off with the helper libraries from the Spark Thermostat project on Github (https://github.com/spark/thermostat)
I’ve included the two .cpp and .h files ( Adafruit_GFX and Adafruit_LEDBackpack). When I compile I get an error that says glcdfont.c is missing.
How do you include a .c file? Do you need to make the .c file with the a library with the make file?
Thanks very much in advance,
Jonathan.
