Need conversion from arduino to Particle photon
I’m a new user to particle photon. I want to convert the following program which is written to an arduino. The following code is for getting readings from pH EZO board.
the code:
#include <SoftwareSerial.h>                           //we have to include the SoftwareSerial library, or else we can't use it
#define rx 2                                          //define what pin rx is going to be
#define tx 3                                          //define what pin tx is going to be
SoftwareSerial myserial(rx, tx);                      //define how the soft serial port is going to work
String inputstring = "";                              //a string to hold incoming data from the PC
String sensorstring = "";                             //a string to hold the data from the Atlas Scientific product
boolean input_string_complete = false;                //have we received all the data from the PC
boolean sensor_string_complete = false;               //have we received all the data from the Atlas Scientific product
float pH;                                             //used to hold a floating point number that is the pH
void setup() {                                        //set up the hardware
  Serial.begin(9600);                                 //set baud rate for the hardware serial port_0 to 9600
  myserial.begin(9600);                               //set baud rate for the software serial port to 9600
  inputstring.reserve(10);                            //set aside some bytes for receiving data from the PC
  sensorstring.reserve(30);                           //set aside some bytes for receiving data from Atlas Scientific product
void serialEvent() {                                  //if the hardware serial port_0 receives a char
  inputstring = Serial.readStringUntil(13);           //read the string until we see a <CR>
  input_string_complete = true;                       //set the flag used to tell if we have received a completed string from the PC
void loop() {                                         //here we go...
  if (input_string_complete == true) {                //if a string from the PC has been received in its entirety
    myserial.print(inputstring);                      //send that string to the Atlas Scientific product
    myserial.print('\r');                             //add a <CR> to the end of the string
    inputstring = "";                                 //clear the string
    input_string_complete = false;                    //reset the flag used to tell if we have received a completed string from the PC
  if (myserial.available() > 0) {                     //if we see that the Atlas Scientific product has sent a character
    char inchar = (char)myserial.read();              //get the char we just received
    sensorstring += inchar;                           //add the char to the var called sensorstring
    if (inchar == '\r') {                             //if the incoming character is a <CR>
      sensor_string_complete = true;                  //set the flag
  if (sensor_string_complete == true) {               //if a string from the Atlas Scientific product has been received in its entirety
    Serial.println(sensorstring);                     //send that string to the PC's serial monitor
    /*                                                //uncomment this section to see how to convert the pH reading from a string to a float
    if (isdigit(sensorstring[0])) {                   //if the first character in the string is a digit
      pH = sensorstring.toFloat();                    //convert the string to a floating point number so it can be evaluated by the Arduino
      if (pH >= 7.0) {                                //if the pH is greater than or equal to 7.0
        Serial.println("high");                       //print "high" this is demonstrating that the Arduino is evaluating the pH as a number and not as a string
      if (pH <= 6.999) {                              //if the pH is less than or equal to 6.999
        Serial.println("low");                        //print "low" this is demonstrating that the Arduino is evaluating the pH as a number and not as a string
    sensorstring = "";                                //clear the string
    sensor_string_complete = false;                   //reset the flag used to tell if we have received a completed string from the Atlas Scientific product
Try this library: https://github.com/ScruffR/ParticleSoftSerial
What exactly do you need ported?
Do you really need the second RX/TX port or would USB Serial plus RX/TX Serial1 suffice?
RX/TX only since the pH EZO Circuit is in UART mode
Then use Serial1 in place of myserial and remove everything related to SoftwareSerial
do i need to use particlsoftserial library ?
@majed, nope. Just follow @ScruffR’s instructions.
Thank you @ScruffR it is working now.
here is the updated code:
  Serial1.begin(9600);                               //set baud rate for the software serial port to 9600
    Serial1.print(inputstring);                      //send that string to the Atlas Scientific product
    Serial1.print('\r');                             //add a <CR> to the end of the string
  if (Serial1.available() > 0) {                     //if we see that the Atlas Scientific product has sent a character
    char inchar = (char)Serial1.read();              //get the char we just received
    Particle.publish("ph", String(sensorstring));
    delay(1000);                    //send that string to the PC's serial monitor
