Need a bit of help with code
Hey everyone …I have a bit of code below and would like to be able to read two separate I/O states in order to enable the next set of commands
int buttonState9 = digitalRead(digitalOUT);
  sensorValue9 = buttonState9;
  if (sensorValue9 ==  HIGH)  {
  Serial.println("HIGH");
  Particle.publish("System Armed","1");
  else if (sensorValue == LOW) {
  Serial.println("LOW");
  int buttonState10 = digitalRead(digitalOUT1);
  sensorValue10 = buttonState10;
  if (sensorValue10 ==  HIGH)  {
  Particle.publish("KeyPad OK","1");
  int buttonState2 = digitalRead(digitalin1);//Bed Motion
  sensorValue1 = buttonState2;
  if (sensorValue1 == LOW) {
  Particle.publish("BedMot","0",PRIVATE);
So what Id like to be able to do is if digitalOUT & digitalOUT1 are high then the Bed Motion PIR is enabled …A little push in a direction would be good …Thanks
You may want to start thinking about specific states (AKA state machine) and progress through the states using the inputs from the various sensors. Something like this pseudo code:
enum MyState{
  SYSTEM_STANDBY,
  SYSTEM_ARMED,
  KEYPAD_OK,
  SENSING_MOTION,
  ALARM_STATE,
  STATES_MAX // just an empty state at the end...
} state = SYSTEM_STANDBY;
MyState lastState = STATES_MAX;
// other globals stuff...
  // Serial stuff
  // Particle stuff
  // pinMode stuff
  if(lastState != state) . // state change detection.  Put here things to do when the states are changed
    switch (state)
      case SYSTEM_STANDBY:
        Serial.println("Standby Mode");
        break;
      case SYSTEM_ARMED:
        Serial.println("ARMED");
        break;
      case KEYPAD_OK:
        Serial.println("Keypad OK");
        break;
      case SENSING_MOTION:
        Serial.println("Sensing Motion");
        break;
      case ALARM_STATE:
        break;
    lastState = state;
  switch (state) . // state management here . Put in each case what events trigger state changes
    case SYSTEM_STANDBY:  // wait here for output on digitalOUT
      if(digitalRead(digitalOUT)
        state = SYSTEM_ARMED;
      break;
    case SYSTEM_ARMED:  // wait here for output on digitalOUT1
      if(digitalRead(digitalOUT1))
        state = KEYPAD_OK;
      break;
    case KEYPAD_OK:
      // do keypadOK stuff here which may bring you to previous or next states
      break;
      // . do motion sensing stuff here
      break;
    case ALARM_STATE:
      // do Alarm things here
      break;
Thanks I’ll give this a shot
