Multiple RFID readers connected to Arduino Uno
Hy,
I have problems with multiple RFID(MFRC522) usage.
I use the MFRC522.h library from https://github.com/miguelbalboa/rfid, and I want to read 8 RFID modules with one Arduino Uno, but I have managed only 2!
I connect all the SPI pins, SS1 to pin10 and SS2 to pin2.
How can I get to read 8 RFID with one Arduino Uno?
#include <SPI.h>
#include <MFRC522.h>
#define RST_PIN         9          // Configurable, see typical pin layout above
#define SS_1_PIN        10         // Configurable, see typical pin layout above
#define SS_2_PIN        2         // Configurable, see typical pin layout above
//#define SS_3_PIN        10
#define LedPin          8
#define NR_OF_READERS  2
byte ssPins[] = {SS_1_PIN, SS_2_PIN};
int a=0;
int b=0;
MFRC522 mfrc522[NR_OF_READERS];   // Create MFRC522 instance.
   * Initialize.
Serial.begin(115200); // Initialize serial communications with the PC
//while (!Serial);    // Do nothing if no serial port is opened (added for Arduinos based on ATMEGA32U4)
pinMode(LedPin,OUTPUT);
SPI.begin();        // Init SPI bus
for (uint8_t reader = 0; reader < NR_OF_READERS; reader++) {
mfrc522[reader].PCD_Init(ssPins[reader], RST_PIN); // Init each MFRC522 card
* Main loop.
   // Look for new cards
if (mfrc522[reader].PICC_IsNewCardPresent() && mfrc522[reader].PICC_ReadCardSerial()) {
  Serial.print(F("Reader: "));
  Serial.print(reader);
  // Show some details of the PICC (that is: the tag/card)
  Serial.print(F(" Card UID:"));
  dump_byte_array(mfrc522[reader].uid.uidByte, mfrc522[reader].uid.size);
  Serial.println();
 Serial.print(F("PICC type: "));
  MFRC522::PICC_Type piccType = mfrc522[reader].PICC_GetType(mfrc522[reader].uid.sak);
  Serial.println(mfrc522[reader].PICC_GetTypeName(piccType));
          if (mfrc522[reader].uid.uidByte[0] == 140 &
          mfrc522[reader].uid.uidByte[1] == 120 &
          mfrc522[reader].uid.uidByte[2] == 34 &
          mfrc522[reader].uid.uidByte[3] == 43 &
          reader==0 ) {
          Serial.println(F("pirmā karte atrasta"));
          a++;
            if (mfrc522[reader].uid.uidByte[0] != 140 &
          mfrc522[reader].uid.uidByte[1] != 120 &
          mfrc522[reader].uid.uidByte[2] != 34 &
          mfrc522[reader].uid.uidByte[3] != 43 &
          reader==0 ) {
          Serial.println(F("pirmā karte nodzes"));
          a=0;
         if (mfrc522[reader].uid.uidByte[0] == 5 &
          mfrc522[reader].uid.uidByte[1] == 233 &
          mfrc522[reader].uid.uidByte[2] == 26 &
          reader==1 ) {
          Serial.println(F("otrā karte atrasta"));
          b++;
      if (mfrc522[reader].uid.uidByte[0] != 5 &
          mfrc522[reader].uid.uidByte[1] != 233 &
          mfrc522[reader].uid.uidByte[2] != 26 &
          reader==1 ) {
          Serial.println(F("otrā karte nodzēs"));
          b=0;
          reader==1 ) {
          b=0;
         reader==0 ) {
          a=0;
Serial.println();
  // Halt PICC
  mfrc522[reader].PICC_HaltA();
  // Stop encryption on PCD
  mfrc522[reader].PCD_StopCrypto1();
  } //if (mfrc522[reader].PICC_IsNewC
  } //for(uint8_t reader
  if (a>0 & b>0)
  digitalWrite(LedPin,HIGH);
   delay(1000);
  digitalWrite(LedPin,LOW);
* Helper routine to dump a byte array as hex values to Serial.
void dump_byte_array(byte *buffer, byte bufferSize) {
for (byte i = 0; i < bufferSize; i++) {
Serial.print(buffer[i] < 0x10 ? " 0" : " ");
Serial.print(buffer[i], HEX);
Hey there, welcome to the Particle community!
Considering you’re talking about the Arduino Uno, I’d like to mention that these forums are actually meant for the Particle devices. Though they share a lot of similarities with Arduinos, there are also a fair share of differences. With that in mind, it’s easier to find support on an Arduino forum I think, since they’re more prone to have encountered things like these before.
You could always get a Particle device to play around with, they’re an awful lot of fun :wink:
Best of luck!
