Multi ds18b20 on thingspeak code
#include "thingspeak/thingspeak.h"
#include "OneWire/OneWire.h"
#include "particle-dallas-temperature/particle-dallas-temperature.h"
ThingSpeakLibrary::ThingSpeak thingspeak ("YOUR API KEY");
// Data wire is plugged into port 2 on the Arduino
#define ONE_WIRE_BUS D2
#define TEMPERATURE_PRECISION 9
int F1temp ;
int F2temp ;
// Setup a oneWire instance to communicate with any OneWire devices (not just Maxim/Dallas temperature ICs)
OneWire oneWire(ONE_WIRE_BUS);
double tempF = 0.0;
double tempC = 0.0;
// Pass our oneWire reference to Dallas Temperature.
DallasTemperature sensors(&oneWire);
// arrays to hold device addresses
DeviceAddress insideThermometer, outsideThermometer;
// function to print a device address
void printAddress(DeviceAddress deviceAddress);
  for (uint8_t i = 0; i < 8; i++)
    // zero pad the address if necessary
    if (deviceAddress[i] < 16) Serial.print("0");
    Serial.print(deviceAddress[i], HEX);
// function to print the temperature for a device
void printTemperature(DeviceAddress deviceAddress);
  float tempC = sensors.getTempC(deviceAddress);
  Serial.print("Temp C: ");
  Serial.print(tempC);
  Serial.print(" Temp F: ");
  Serial.print(DallasTemperature::toFahrenheit(tempC));
// function to print a device's resolution
void printResolution(DeviceAddress deviceAddress);
  Serial.print("Resolution: ");
  Serial.print(sensors.getResolution(deviceAddress));
  Serial.println();
// main function to print information about a device
void printData(DeviceAddress deviceAddress);
  Serial.print("Device Address: ");
  printAddress(deviceAddress);
  Serial.print(" ");
  printTemperature(deviceAddress);
  Serial.println();
void setup(void)
  sensors.begin();// start serial port
  Serial.println("Dallas Temperature IC Control Library Demo");
  Spark.variable("tempf", &tempF, DOUBLE);
  // Start up the library
  sensors.begin();
  // locate devices on the bus
  Serial.print("Locating devices...");
  Serial.print("Found ");
  Serial.print(sensors.getDeviceCount(), DEC);
  Serial.println(" devices.");
  // report parasite power requirements
  Serial.print("Parasite power is: ");
  if (sensors.isParasitePowerMode()) Serial.println("ON");
  else Serial.println("OFF");
  // assign address manually.  the addresses below will beed to be changed
  // to valid device addresses on your bus.  device address can be retrieved
  // by using either oneWire.search(deviceAddress) or individually via
  // sensors.getAddress(deviceAddress, index)
  //insideThermometer = { 0x28, 0x1D, 0x39, 0x31, 0x2, 0x0, 0x0, 0xF0 };
  //outsideThermometer   = { 0x28, 0x3F, 0x1C, 0x31, 0x2, 0x0, 0x0, 0x2 };
  // search for devices on the bus and assign based on an index.  ideally,
  // you would do this to initially discover addresses on the bus and then
  // use those addresses and manually assign them (see above) once you know
  // the devices on your bus (and assuming they don't change).
  // method 1: by index
  if (!sensors.getAddress(insideThermometer, 0)) Serial.println("Unable to find address for Device 0");
  if (!sensors.getAddress(outsideThermometer, 1)) Serial.println("Unable to find address for Device 1");
  // method 2: search()
  // search() looks for the next device. Returns 1 if a new address has been
  // returned. A zero might mean that the bus is shorted, there are no devices,
  // or you have already retrieved all of them.  It might be a good idea to
  // check the CRC to make sure you didn't get garbage.  The order is
  // deterministic. You will always get the same devices in the same order
  // Must be called before search()
  //oneWire.reset_search();
  // assigns the first address found to insideThermometer
  //if (!oneWire.search(insideThermometer)) Serial.println("Unable to find address for insideThermometer");
  // assigns the seconds address found to outsideThermometer
  //if (!oneWire.search(outsideThermometer)) Serial.println("Unable to find address for outsideThermometer");
  // show the addresses we found on the bus
  Serial.print("Device 0 Address: ");
  printAddress(insideThermometer);
  Serial.println();
  Serial.print("Device 1 Address: ");
  printAddress(outsideThermometer);
  Serial.println();
  // set the resolution to 9 bit
  sensors.setResolution(insideThermometer, TEMPERATURE_PRECISION);
  sensors.setResolution(outsideThermometer, TEMPERATURE_PRECISION);
  Serial.print("Device 0 Resolution: ");
  //Serial.print(sensors.getResolution(insideThermometer), DEC);
  Serial.println();
  Serial.print("Device 1 Resolution: ");
  //Serial.print(sensors.getResolution(outsideThermometer), DEC);
  Serial.println();
void loop(void)
  // call sensors.requestTemperatures() to issue a global temperature
  // request to all devices on the bus
  Serial.print("Requesting temperatures...");
  sensors.requestTemperatures();
  Serial.println("DONE");
  delay(1000);
  // print the device information
  printData(insideThermometer);
  printData(outsideThermometer);sensors.requestTemperatures();
  tempC = sensors.getTempCByIndex(0);
  tempF = tempC * 9.0 / 5.0 + 32.0;
  int WT = sensors.getTempC(insideThermometer);
 F1temp = (WT * 9.0)/ 5.0 + 32.0;
 int OT = sensors.getTempC(outsideThermometer);
 F2temp = (OT * 9.0)/ 5.0 + 32.0;
  bool valSet = thingspeak.recordValue(1, String(F1temp, DEC));
  bool valSet1 = thingspeak.recordValue(8, String(F2temp, DEC));
  bool valsSent= thingspeak.sendValues();
  bool valsSent1= thingspeak.sendValues();
Would you care to tell us a bit more about this?
well i originally had an arduino board with Ethernet shield setup and sending info to my thingspeak page. so when the photon came out i wanted to use this instead of the arduino board so i went to work and picked apart other users codes . now i have a working photon sending temperature to Thingspeak.
@fcw158 Thank you so much for the code. I have had a couple weird things I’m trying to troubleshoot and thought I’d see if you knew what was up. I’m using your exact code, but only have one sensor attached. The temperature is close, but seems to float within a couple degree F range despite the room ranging 10 degrees or so during the day. I also get occasional -196 degree readings. Any thoughts on what might be causing this?
tfoxsf
let me look into this.
fred
tfoxsf,
at what height are your sensors? i have two DS18b20 setup in the same room and one is at 6 feet high the other is at 2 feet high and i have a 3-4 degree difference this is not unusual . also the 196 F reading i get the same reading once in a while when i refresh my screen it fixes the readings. I have read other users of thingspeak having the same issue asking if there is a way to refresh. if you use google chrome you can refresh every 10 seconds.
fred
Are you using the CRC feature of the DS18B20 sensors ?
mora,
no the sketch is not using the CRC feature . I will have to look into this.
thank you
Awesome. Thanks Fred. I put another thermometer right next to the particle one and it seems to be accurate. Before I had one high and low like you had mentioned.
are you still get the 196 degree reading?
mora,
i reviewed the sketch and noticed it uses the dallas -dallas-temperature.cpp
which uses the CRC .
fred
I am still getting the -196 reading. Link to my Thingspeak channel below. It seems be be related to the internet dropping off. My Dropcam has also had intermittent trouble maintaining a constant video feed upstairs.
https://thingspeak.com/channels/56934
#include <ThingSpeak.h>
#include <OneWire.h>
#include "spark-dallas-temperature.h"
int F1temp ;
int F2temp ;
double tempF = 0.0;
double tempC = 0.0;
    //Serial.print(deviceAddress[i], HEX);
 // Serial.print("Temp C: ");
 // Serial.print(tempC);
 // Serial.print(" Temp F: ");
 // Serial.print(DallasTemperature::toFahrenheit(tempC));
 // Serial.print("Resolution: ");
 // Serial.print(sensors.getResolution(deviceAddress));
// Serial.println();
 // Serial.print("Device Address: ");
 // printAddress(deviceAddress);
 // Serial.print(" ");
 // printTemperature(deviceAddress);
TCPClient client;
unsigned long myChannelNumber = 1234;// YOUR THINGSPEAK CHANNEL ID
const char * myWriteAPIKey = "abcdefgh1234";//YOUR THINGSPEAK API KEY
void setup(void)
    ThingSpeak.begin(client);
 // Serial.begin(9600);
 // Serial.println("Dallas Temperature IC Control Library Demo");
//  particle.variable("tempf", &tempF, DOUBLE);
  sensors.begin();
  //Serial.print("Locating devices...");
 //Serial.print("Found ");
 //Serial.print(sensors.getDeviceCount(), DEC);
 // Serial.println(" devices.");
 // Serial.print("Parasite power is: ");
 // Serial.print("Device 0 Address: ");
 // Serial.print("Device 1 Address: ");
  //Serial.println();
 // Serial.print("Device 0 Resolution: ");
  //Serial.print("Device 1 Resolution: ");
void loop(void)
 // Serial.print("Requesting temperatures...");
 // Serial.println("DONE");
  delay(100);
 ThingSpeak.writeField(myChannelNumber, 1, F2temp, myWriteAPIKey);
 ThingSpeak.writeField(myChannelNumber, 8, F1temp, myWriteAPIKey);
  delay(100);
spark-dallas-temperature.cpp
// This library is free software; you can redistribute it and/or
// modify it under the terms of the GNU Lesser General Public
// License as published by the Free Software Foundation; either
// version 2.1 of the License, or (at your option) any later version.
// Version 3.7.2 modified on Dec 6, 2011 to support Arduino 1.0
// See Includes...
// Modified by Jordan Hochenbaum
// Modified by Tom de Boer @ 26-jun-2014 (Spark Core compatibility)
DallasTemperature::DallasTemperature(OneWire* _oneWire)
#if REQUIRESALARMS
    : _AlarmHandler(&defaultAlarmHandler)
#endif
    _wire = _oneWire;
    devices = 0;
    parasite = false;
    bitResolution = 9;
    waitForConversion = true;
    checkForConversion = true;
// initialise the bus
void DallasTemperature::begin(void)
    DeviceAddress deviceAddress;
    _wire->reset_search();
    devices = 0; // Reset the number of devices when we enumerate wire devices
    while (_wire->search(deviceAddress))
        if (validAddress(deviceAddress))
            if (!parasite && readPowerSupply(deviceAddress)) parasite = true;
            ScratchPad scratchPad;
            readScratchPad(deviceAddress, scratchPad);
            bitResolution = max(bitResolution, getResolution(deviceAddress));
            devices++;
// returns the number of devices found on the bus
uint8_t DallasTemperature::getDeviceCount(void)
    return devices;
// returns true if address is valid
bool DallasTemperature::validAddress(const uint8_t* deviceAddress)
    return (_wire->crc8((uint8_t*)deviceAddress, 7) == deviceAddress[7]);
// finds an address at a given index on the bus
// returns true if the device was found
bool DallasTemperature::getAddress(uint8_t* deviceAddress, uint8_t index)
    uint8_t depth = 0;
    while (depth <= index && _wire->search(deviceAddress))
        if (depth == index && validAddress(deviceAddress)) return true;
        depth++;
    return false;
// attempt to determine if the device at the given address is connected to the bus
bool DallasTemperature::isConnected(const uint8_t* deviceAddress)
    return isConnected(deviceAddress, scratchPad);
// also allows for updating the read scratchpad
bool DallasTemperature::isConnected(const uint8_t* deviceAddress, uint8_t* scratchPad)
    return (_wire->crc8(scratchPad, 8) == scratchPad[SCRATCHPAD_CRC]);
// read device's scratch pad
void DallasTemperature::readScratchPad(const uint8_t* deviceAddress, uint8_t* scratchPad)
    // send the command
    _wire->reset();
    _wire->select(deviceAddress);
    _wire->write(READSCRATCH);
    // TODO => collect all comments &  use simple loop
    // byte 0: temperature LSB
    // byte 1: temperature MSB
    // byte 2: high alarm temp
    // byte 3: low alarm temp
    // byte 4: DS18S20: store for crc
    //         DS18B20 & DS1822: configuration register
    // byte 5: internal use & crc
    // byte 6: DS18S20: COUNT_REMAIN
    //         DS18B20 & DS1822: store for crc
    // byte 7: DS18S20: COUNT_PER_C
    // byte 8: SCRATCHPAD_CRC
    // for(int i=0; i<9; i++)
    //   scratchPad[i] = _wire->read();
    // read the response
    scratchPad[TEMP_LSB] = _wire->read();
    scratchPad[TEMP_MSB] = _wire->read();
    scratchPad[HIGH_ALARM_TEMP] = _wire->read();
    scratchPad[LOW_ALARM_TEMP] = _wire->read();
    // byte 4:
    // DS18S20: store for crc
    scratchPad[CONFIGURATION] = _wire->read();
    // byte 5:
    // internal use & crc
    scratchPad[INTERNAL_BYTE] = _wire->read();
    // byte 6:
    // DS18S20: COUNT_REMAIN
    scratchPad[COUNT_REMAIN] = _wire->read();
    // byte 7:
    // DS18S20: COUNT_PER_C
    scratchPad[COUNT_PER_C] = _wire->read();
    // byte 8:
    // SCTRACHPAD_CRC
    scratchPad[SCRATCHPAD_CRC] = _wire->read();
    _wire->reset();
// writes device's scratch pad
void DallasTemperature::writeScratchPad(const uint8_t* deviceAddress, const uint8_t* scratchPad)
    _wire->reset();
    _wire->write(WRITESCRATCH);
    _wire->write(scratchPad[HIGH_ALARM_TEMP]); // high alarm temp
    _wire->write(scratchPad[LOW_ALARM_TEMP]); // low alarm temp
    // DS1820 and DS18S20 have no configuration register
    if (deviceAddress[0] != DS18S20MODEL) _wire->write(scratchPad[CONFIGURATION]); // configuration
    _wire->reset();
    _wire->select(deviceAddress); //<--this line was missing
    // save the newly written values to eeprom
    _wire->write(COPYSCRATCH, parasite);
    if (parasite) delay(10); // 10ms delay
    _wire->reset();
// reads the device's power requirements
bool DallasTemperature::readPowerSupply(const uint8_t* deviceAddress)
    bool ret = false;
    _wire->reset();
    _wire->write(READPOWERSUPPLY);
    if (_wire->read_bit() == 0) ret = true;
    _wire->reset();
    return ret;
// set resolution of all devices to 9, 10, 11, or 12 bits
// if new resolution is out of range, it is constrained.
void DallasTemperature::setResolution(uint8_t newResolution)
    bitResolution = constrain(newResolution, 9, 12);
    for (int i=0; i<devices; i++)
        getAddress(deviceAddress, i);
        setResolution(deviceAddress, bitResolution);
// set resolution of a device to 9, 10, 11, or 12 bits
// if new resolution is out of range, 9 bits is used.
bool DallasTemperature::setResolution(const uint8_t* deviceAddress, uint8_t newResolution)
    if (isConnected(deviceAddress, scratchPad))
        // DS1820 and DS18S20 have no resolution configuration register
            switch (newResolution)
            case 12:
                scratchPad[CONFIGURATION] = TEMP_12_BIT;
                break;
            case 11:
                scratchPad[CONFIGURATION] = TEMP_11_BIT;
                break;
            case 10:
                scratchPad[CONFIGURATION] = TEMP_10_BIT;
                break;
            case 9:
            default:
                scratchPad[CONFIGURATION] = TEMP_9_BIT;
                break;
            writeScratchPad(deviceAddress, scratchPad);
        return true;  // new value set
    return false;
// returns the global resolution
uint8_t DallasTemperature::getResolution()
    return bitResolution;
// returns the current resolution of the device, 9-12
// returns 0 if device not found
uint8_t DallasTemperature::getResolution(const uint8_t* deviceAddress)
    if (deviceAddress[0] == DS18S20MODEL) return 12;
        switch (scratchPad[CONFIGURATION])
        case TEMP_12_BIT:
            return 12;
        case TEMP_11_BIT:
            return 11;
        case TEMP_10_BIT:
            return 10;
        case TEMP_9_BIT:
            return 9;
    return 0;
// sets the value of the waitForConversion flag
// TRUE : function requestTemperature() etc returns when conversion is ready
// FALSE: function requestTemperature() etc returns immediately (USE WITH CARE!!)
//        (1) programmer has to check if the needed delay has passed
//        (2) but the application can do meaningful things in that time
void DallasTemperature::setWaitForConversion(bool flag)
    waitForConversion = flag;
// gets the value of the waitForConversion flag
bool DallasTemperature::getWaitForConversion()
    return waitForConversion;
// sets the value of the checkForConversion flag
// TRUE : function requestTemperature() etc will 'listen' to an IC to determine whether a conversion is complete
// FALSE: function requestTemperature() etc will wait a set time (worst case scenario) for a conversion to complete
void DallasTemperature::setCheckForConversion(bool flag)
    checkForConversion = flag;
bool DallasTemperature::getCheckForConversion()
    return checkForConversion;
bool DallasTemperature::isConversionAvailable(const uint8_t* deviceAddress)
    // Check if the clock has been raised indicating the conversion is complete
    return scratchPad[0];
// sends command for all devices on the bus to perform a temperature conversion
void DallasTemperature::requestTemperatures()
    _wire->reset();
    _wire->skip();
    _wire->write(STARTCONVO, parasite);
    // ASYNC mode?
    if (!waitForConversion) return;
    blockTillConversionComplete(bitResolution, NULL);
// sends command for one device to perform a temperature by address
// returns FALSE if device is disconnected
// returns TRUE  otherwise
bool DallasTemperature::requestTemperaturesByAddress(const uint8_t* deviceAddress)
    _wire->reset();
    // check device
    if (!isConnected(deviceAddress, scratchPad)) return false;
    // ASYNC mode?
    if (!waitForConversion) return true;
    blockTillConversionComplete(getResolution(deviceAddress), deviceAddress);
    return true;
// returns number of milliseconds to wait till conversion is complete (based on IC datasheet)
int16_t DallasTemperature::millisToWaitForConversion(uint8_t bitResolution)
    switch (bitResolution)
    case 9:
        return 94;
    case 10:
        return 188;
    case 11:
        return 375;
    default:
        return 750;
// Continue to check if the IC has responded with a temperature
void DallasTemperature::blockTillConversionComplete(uint8_t bitResolution, const uint8_t* deviceAddress)
    int delms = millisToWaitForConversion(bitResolution);
    if (deviceAddress != NULL && checkForConversion && !parasite)
        unsigned long timend = millis() + delms;
        while(!isConversionAvailable(deviceAddress) && (millis() < timend));
    else
        delay(delms);
// sends command for one device to perform a temp conversion by index
bool DallasTemperature::requestTemperaturesByIndex(uint8_t deviceIndex)
    getAddress(deviceAddress, deviceIndex);
    return requestTemperaturesByAddress(deviceAddress);
// Fetch temperature for device index
float DallasTemperature::getTempCByIndex(uint8_t deviceIndex)
    if (!getAddress(deviceAddress, deviceIndex))
        return DEVICE_DISCONNECTED_C;
    return getTempC((uint8_t*)deviceAddress);
float DallasTemperature::getTempFByIndex(uint8_t deviceIndex)
        return DEVICE_DISCONNECTED_F;
    return getTempF((uint8_t*)deviceAddress);
// reads scratchpad and returns fixed-point temperature, scaling factor 2^-7
int16_t DallasTemperature::calculateTemperature(const uint8_t* deviceAddress, uint8_t* scratchPad)
    int16_t fpTemperature =
        (((int16_t) scratchPad[TEMP_MSB]) << 11) |
        (((int16_t) scratchPad[TEMP_LSB]) << 3);
    DS1820 and DS18S20 have a 9-bit temperature register.
    Resolutions greater than 9-bit can be calculated using the data from
    the temperature, and COUNT REMAIN and COUNT PER °C registers in the
    scratchpad.  The resolution of the calculation depends on the model.
    While the COUNT PER °C register is hard-wired to 16 (10h) in a
    DS18S20, it changes with temperature in DS1820.
    After reading the scratchpad, the TEMP_READ value is obtained by
    truncating the 0.5°C bit (bit 0) from the temperature data. The
    extended resolution temperature can then be calculated using the
    following equation:
                                    COUNT_PER_C - COUNT_REMAIN
    TEMPERATURE = TEMP_READ - 0.25 + --------------------------
                                            COUNT_PER_C
    Hagai Shatz simplified this to integer arithmetic for a 12 bits
    value for a DS18S20, and James Cameron added legacy DS1820 support.
    See - http://myarduinotoy.blogspot.co.uk/2013/02/12bit-result-from-ds18s20.html
        fpTemperature = ((fpTemperature & 0xfff0) << 3) - 16 +
                ((scratchPad[COUNT_PER_C] - scratchPad[COUNT_REMAIN]) << 7) /
    return fpTemperature;
// returns temperature in 1/128 degrees C or DEVICE_DISCONNECTED_RAW if the
// device's scratch pad cannot be read successfully.
// the numeric value of DEVICE_DISCONNECTED_RAW is defined in
// DallasTemperature.h. It is a large negative number outside the
// operating range of the device
int16_t DallasTemperature::getTemp(const uint8_t* deviceAddress)
    if (isConnected(deviceAddress, scratchPad)) return calculateTemperature(deviceAddress, scratchPad);
    return DEVICE_DISCONNECTED_RAW;
// returns temperature in degrees C or DEVICE_DISCONNECTED_C if the
// the numeric value of DEVICE_DISCONNECTED_C is defined in
float DallasTemperature::getTempC(const uint8_t* deviceAddress)
    return rawToCelsius(getTemp(deviceAddress));
// returns temperature in degrees F or DEVICE_DISCONNECTED_F if the
// the numeric value of DEVICE_DISCONNECTED_F is defined in
float DallasTemperature::getTempF(const uint8_t* deviceAddress)
    return rawToFahrenheit(getTemp(deviceAddress));
// returns true if the bus requires parasite power
bool DallasTemperature::isParasitePowerMode(void)
    return parasite;
#if REQUIRESALARMS
ALARMS:
TH and TL Register Format
BIT 7 BIT 6 BIT 5 BIT 4 BIT 3 BIT 2 BIT 1 BIT 0
  S    2^6   2^5   2^4   2^3   2^2   2^1   2^0
Only bits 11 through 4 of the temperature register are used
in the TH and TL comparison since TH and TL are 8-bit
registers. If the measured temperature is lower than or equal
to TL or higher than or equal to TH, an alarm condition exists
and an alarm flag is set inside the DS18B20. This flag is
updated after every temperature measurement; therefore, if the
alarm condition goes away, the flag will be turned off after
the next temperature conversion.
// sets the high alarm temperature for a device in degrees Celsius
// accepts a float, but the alarm resolution will ignore anything
// after a decimal point.  valid range is -55C - 125C
void DallasTemperature::setHighAlarmTemp(const uint8_t* deviceAddress, char celsius)
    // make sure the alarm temperature is within the device's range
    if (celsius > 125) celsius = 125;
    else if (celsius < -55) celsius = -55;
        scratchPad[HIGH_ALARM_TEMP] = (uint8_t)celsius;
// sets the low alarm temperature for a device in degrees Celsius
void DallasTemperature::setLowAlarmTemp(const uint8_t* deviceAddress, char celsius)
        scratchPad[LOW_ALARM_TEMP] = (uint8_t)celsius;
// returns a char with the current high alarm temperature or
// DEVICE_DISCONNECTED for an address
char DallasTemperature::getHighAlarmTemp(const uint8_t* deviceAddress)
    if (isConnected(deviceAddress, scratchPad)) return (char)scratchPad[HIGH_ALARM_TEMP];
// returns a char with the current low alarm temperature or
char DallasTemperature::getLowAlarmTemp(const uint8_t* deviceAddress)
    if (isConnected(deviceAddress, scratchPad)) return (char)scratchPad[LOW_ALARM_TEMP];
// resets internal variables used for the alarm search
void DallasTemperature::resetAlarmSearch()
    alarmSearchJunction = -1;
    alarmSearchExhausted = 0;
    for(uint8_t i = 0; i < 7; i++)
        alarmSearchAddress[i] = 0;
// This is a modified version of the OneWire::search method.
// Also added the OneWire search fix documented here:
// http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1238032295
// Perform an alarm search. If this function returns a '1' then it has
// enumerated the next device and you may retrieve the ROM from the
// OneWire::address variable. If there are no devices, no further
// devices, or something horrible happens in the middle of the
// enumeration then a 0 is returned.  If a new device is found then
// its address is copied to newAddr.  Use
// DallasTemperature::resetAlarmSearch() to start over.
bool DallasTemperature::alarmSearch(uint8_t* newAddr)
    uint8_t i;
    char lastJunction = -1;
    uint8_t done = 1;
    if (alarmSearchExhausted) return false;
    if (!_wire->reset()) return false;
    // send the alarm search command
    _wire->write(0xEC, 0);
    for(i = 0; i < 64; i++)
        uint8_t a = _wire->read_bit( );
        uint8_t nota = _wire->read_bit( );
        uint8_t ibyte = i / 8;
        uint8_t ibit = 1 << (i & 7);
        // I don't think this should happen, this means nothing responded, but maybe if
        // something vanishes during the search it will come up.
        if (a && nota) return false;
        if (!a && !nota)
            if (i == alarmSearchJunction)
                // this is our time to decide differently, we went zero last time, go one.
                a = 1;
                alarmSearchJunction = lastJunction;
            else if (i < alarmSearchJunction)
                // take whatever we took last time, look in address
                if (alarmSearchAddress[ibyte] & ibit) a = 1;
                else
                    // Only 0s count as pending junctions, we've already exhausted the 0 side of 1s
                    a = 0;
                    done = 0;
                    lastJunction = i;
            else
                // we are blazing new tree, take the 0
                a = 0;
                alarmSearchJunction = i;
                done = 0;
            // OneWire search fix
            // See: http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1238032295
        if (a) alarmSearchAddress[ibyte] |= ibit;
        else alarmSearchAddress[ibyte] &= ~ibit;
        _wire->write_bit(a);
    if (done) alarmSearchExhausted = 1;
    for (i = 0; i < 8; i++) newAddr[i] = alarmSearchAddress[i];
    return true;
// returns true if device address might have an alarm condition
// (only an alarm search can verify this)
bool DallasTemperature::hasAlarm(const uint8_t* deviceAddress)
        char temp = calculateTemperature(deviceAddress, scratchPad) >> 7;
        // check low alarm
        if (temp <= (char)scratchPad[LOW_ALARM_TEMP]) return true;
        // check high alarm
        if (temp >= (char)scratchPad[HIGH_ALARM_TEMP]) return true;
    // no alarm
    return false;
// returns true if any device is reporting an alarm condition on the bus
bool DallasTemperature::hasAlarm(void)
    resetAlarmSearch();
    return alarmSearch(deviceAddress);
// runs the alarm handler for all devices returned by alarmSearch()
void DallasTemperature::processAlarms(void)
    resetAlarmSearch();
    DeviceAddress alarmAddr;
    while (alarmSearch(alarmAddr))
        if (validAddress(alarmAddr))
            _AlarmHandler(alarmAddr);
// sets the alarm handler
void DallasTemperature::setAlarmHandler(AlarmHandler *handler)
    _AlarmHandler = handler;
// The default alarm handler
void DallasTemperature::defaultAlarmHandler(const uint8_t* deviceAddress)
#endif
// Convert float Celsius to Fahrenheit
float DallasTemperature::toFahrenheit(float celsius)
    return (celsius * 1.8) + 32;
// Convert float Fahrenheit to Celsius
float DallasTemperature::toCelsius(float fahrenheit)
    return (fahrenheit - 32) * 0.555555556;
// convert from raw to Celsius
float DallasTemperature::rawToCelsius(int16_t raw)
    if (raw <= DEVICE_DISCONNECTED_RAW)
    // C = RAW/128
    return (float)raw * 0.0078125;
// convert from raw to Fahrenheit
float DallasTemperature::rawToFahrenheit(int16_t raw)
    // C = RAW/128
    // F = (C*1.8)+32 = (RAW/128*1.8)+32 = (RAW*0.0140625)+32
    return ((float)raw * 0.0140625) + 32;
#if REQUIRESNEW
// MnetCS - Allocates memory for DallasTemperature. Allows us to instance a new object
void* DallasTemperature::operator new(unsigned int size) // Implicit NSS obj size
    void * p; // void pointer
    p = malloc(size); // Allocate memory
    memset((DallasTemperature*)p,0,size); // Initialise memory
    //!!! CANT EXPLICITLY CALL CONSTRUCTOR - workaround by using an init() methodR - workaround by using an init() method
    return (DallasTemperature*) p; // Cast blank region to NSS pointer
// MnetCS 2009 -  Free the memory used by this instance
void DallasTemperature::operator delete(void* p)
    DallasTemperature* pNss =  (DallasTemperature*) p; // Cast to NSS pointer
    pNss->~DallasTemperature(); // Destruct the object
    free(p); // Free the memory
#endif
Heading
#ifndef DallasTemperature_h
#define DallasTemperature_h
#define DALLASTEMPLIBVERSION "3.7.2"
// set to true to include code for new and delete operators
#ifndef REQUIRESNEW
#define REQUIRESNEW false
#endif
// set to true to include code implementing alarm search functions
#ifndef REQUIRESALARMS
#define REQUIRESALARMS true
#endif
#include <inttypes.h>
#if defined(ARDUINO) && ARDUINO >= 100
#elif defined(SPARK) or defined(STM32F10X_MD)
    #include "application.h"
    #include "OneWire.h"
#endif
// Model IDs
#define DS18S20MODEL 0x10  // also DS1820
#define DS18B20MODEL 0x28
#define DS1822MODEL  0x22
#define DS1825MODEL  0x3B
// OneWire commands
#define STARTCONVO      0x44  // Tells device to take a temperature reading and put it on the scratchpad
#define COPYSCRATCH     0x48  // Copy EEPROM
#define READSCRATCH     0xBE  // Read EEPROM
#define WRITESCRATCH    0x4E  // Write to EEPROM
#define RECALLSCRATCH   0xB8  // Reload from last known
#define READPOWERSUPPLY 0xB4  // Determine if device needs parasite power
#define ALARMSEARCH     0xEC  // Query bus for devices with an alarm condition
// Scratchpad locations
#define TEMP_LSB        0
#define TEMP_MSB        1
#define HIGH_ALARM_TEMP 2
#define LOW_ALARM_TEMP  3
#define CONFIGURATION   4
#define INTERNAL_BYTE   5
#define COUNT_REMAIN    6
#define COUNT_PER_C     7
#define SCRATCHPAD_CRC  8
// Device resolution
#define TEMP_9_BIT  0x1F //  9 bit
#define TEMP_10_BIT 0x3F // 10 bit
#define TEMP_11_BIT 0x5F // 11 bit
#define TEMP_12_BIT 0x7F // 12 bit
// Error Codes
#define DEVICE_DISCONNECTED_C -127
#define DEVICE_DISCONNECTED_F -196.6
#define DEVICE_DISCONNECTED_RAW -2032
typedef uint8_t DeviceAddress[8];
class DallasTemperature
  public:
  DallasTemperature(OneWire*);
  // initialise bus
  void begin(void);
  uint8_t getDeviceCount(void);
  bool validAddress(const uint8_t*);
  bool getAddress(uint8_t*, uint8_t);
  bool isConnected(const uint8_t*);
  bool isConnected(const uint8_t*, uint8_t*);
  // read device's scratchpad
  void readScratchPad(const uint8_t*, uint8_t*);
  // write device's scratchpad
  void writeScratchPad(const uint8_t*, const uint8_t*);
  // read device's power requirements
  bool readPowerSupply(const uint8_t*);
  // get global resolution
  uint8_t getResolution();
  // set global resolution to 9, 10, 11, or 12 bits
  void setResolution(uint8_t);
  // returns the device resolution: 9, 10, 11, or 12 bits
  uint8_t getResolution(const uint8_t*);
  bool setResolution(const uint8_t*, uint8_t);
  // sets/gets the waitForConversion flag
  void setWaitForConversion(bool);
  bool getWaitForConversion(void);
  // sets/gets the checkForConversion flag
  void setCheckForConversion(bool);
  bool getCheckForConversion(void);
  void requestTemperatures(void);
  // sends command for one device to perform a temperature conversion by address
  bool requestTemperaturesByAddress(const uint8_t*);
  // sends command for one device to perform a temperature conversion by index
  bool requestTemperaturesByIndex(uint8_t);
  // returns temperature raw value (12 bit integer of 1/16 degrees C)
  int16_t getTemp(const uint8_t*);
  float getTempC(const uint8_t*);
  float getTempF(const uint8_t*);
  // Get temperature for device index (slow)
  float getTempCByIndex(uint8_t);
  float getTempFByIndex(uint8_t);
  bool isParasitePowerMode(void);
  bool isConversionAvailable(const uint8_t*);
  #if REQUIRESALARMS
  typedef void AlarmHandler(const uint8_t*);
  // accepts a char.  valid range is -55C - 125C
  void setHighAlarmTemp(const uint8_t*, char);
  void setLowAlarmTemp(const uint8_t*, char);
  // returns a signed char with the current high alarm temperature for a device
  // in the range -55C - 125C
  char getHighAlarmTemp(const uint8_t*);
  // returns a signed char with the current low alarm temperature for a device
  char getLowAlarmTemp(const uint8_t*);
  void resetAlarmSearch(void);
  // search the wire for devices with active alarms
  bool alarmSearch(uint8_t*);
  // returns true if ia specific device has an alarm
  bool hasAlarm(const uint8_t*);
  // returns true if any device is reporting an alarm on the bus
  bool hasAlarm(void);
  void processAlarms(void);
  void setAlarmHandler(const AlarmHandler *);
  static void defaultAlarmHandler(const uint8_t*);
  #endif
  // convert from Celsius to Fahrenheit
  static float toFahrenheit(float);
  // convert from Fahrenheit to Celsius
  static float toCelsius(float);
  static float rawToCelsius(int16_t);
  static float rawToFahrenheit(int16_t);
  #if REQUIRESNEW
  // initialize memory area
  void* operator new (unsigned int);
  // delete memory reference
  void operator delete(void*);
  #endif
  private:
  typedef uint8_t ScratchPad[9];
  // parasite power on or off
  bool parasite;
  // used to determine the delay amount needed to allow for the
  // temperature conversion to take place
  uint8_t bitResolution;
  // used to requestTemperature with or without delay
  bool waitForConversion;
  // used to requestTemperature to dynamically check if a conversion is complete
  bool checkForConversion;
  // count of devices on the bus
  uint8_t devices;
  // Take a pointer to one wire instance
  OneWire* _wire;
  // reads scratchpad and returns the raw temperature
  int16_t calculateTemperature(const uint8_t*, uint8_t*);
  int16_t millisToWaitForConversion(uint8_t);
  void  blockTillConversionComplete(uint8_t, const uint8_t*);
  #if REQUIRESALARMS
  // required for alarmSearch
  uint8_t alarmSearchAddress[8];
  char alarmSearchJunction;
  uint8_t alarmSearchExhausted;
  // the alarm handler function pointer
  AlarmHandler *_AlarmHandler;
  #endif
#endif
So… What exactly is the purpose of this post? Just dumping code without some kind of explanation doesn’t really say a lot (literally).
This is an update to a post i did back in August 2015 . I went back to my project an noticed the original project did not work with the new library 2.0. so i went thru and re worked the project with the new library.
THANK YOU for your help
