I am attempting to integrate openHAB with a Particle Photon using Mosquitto MQTT server to ultimately open/close a relay but the subscribe function does not want to work in the Photon code. I have adapted code published by hirotakaster on github. I have 2 topics configured in my openHAB item one called “relaystatus” and the other “setrelaystatus” and my sitemap is setup to display the “relaystatus” value (via subscribe) and toggle “setrelaystatus” (publish) between on and off via a toggle button. When testing I can see a value for “relaystatus” on my sitemap so this seems to be working. The problem seems to be with the “setrelaystatus” topic and specifically that the Photon either does not get the on/off message or it does receive them but it doesn’t actually “write” to the specified interface. What should happen if all was working correctly is when a move the sitemap toggle to the on position openHAB should publish the message “on” to MQTT topic “setrelaystatus”; my photon subscribes to this topic so it should receive this message, and its code should tell it to send a digitalWrite HIGH command to led1 (A0) or LOW if the message recieved is “off”. Using MQTTlens to also subscribe to the “setrelaystatus” topic I can see the message “on” being published by openHAB so it seems my OpenHAB and MQTT config are correct and able to communicate. Additionally the Photon can communicate with my MQTT broker and ultimately openHAB since I see messages in the topic “relaystatus” which can only come from the Photon. As I type this I am becoming more and more convinced that the issue is the Photon specifically what it does or in this case doesn’t do in response to the “setrelaystatus” topic messages. Any help would be greatly appreciated. Below is my Photon code please let me know if further info is needed.
#include "NCD1Relay.h"
#include "MQTT.h"
void callback(char* topic, byte* payload, unsigned int length);
* if want to use IP address,
* byte server[] = { XXX,XXX,XXX,XXX };
* MQTT client(server, 1883, callback);
* want to use domain name,
* MQTT client("www.sample.com", 1883, callback);
byte server[] = {172,30,10,5};
NCD1Relay controller;
int relayStatus;
int setrelaystatus;
int led1 = A0;
unsigned long lastSend = 0;
unsigned long sendInterval = 2000;
// recieve message
void callback(char* topic, byte* payload, unsigned int length) {
char p[length + 1];
memcpy(p, payload, length);
p[length] = NULL;
String message(p);
String t = String(topic);
Serial.println(t);
Serial.println(message);
if(message.equals("on"))
digitalWrite(led1, HIGH);
else if(message.equals("off"))
digitalWrite(led1, LOW);
controller.setAddress(0,0,0);
relayStatus = controller.readRelayStatus();
// connect to the server
client.connect("NCD1 Relay controller");
// publish/subscribe
if (client.isConnected()) {
client.subscribe("setrelaystatus");
client.publish("outTopic","hello world");
client.subscribe("outTopic");
delay(1000);
if (client.isConnected()){
client.loop();
if(millis() >= lastSend+sendInterval){
lastSend = millis();
client.publish("relaystatus",String(relayStatus));
