palitu
March 18, 2016, 1:05am
#1
I want to use my Particle with a local Mosquitto MQTT server, to both publish and subscribe to topics.
What is the current reliability of the hosted MQTT library?
There are numerous threads about it, but i am chasing the latest info, if anyone can help
Palitu
palitu
March 21, 2016, 11:58pm
#2
An update - My guess is that it is not an appropriate library for anything in production.
I ran a test last night, sending a message at 10s intervals to my MQTT broker. It lasted 5 hours before stopping.
This is not to take away from the great guys who built the library, but it is not ready for prime time on the particle’s
Thanks for testing. I’m sorry to hear that; was hoping to use that library.
I’ve got multiple projects using MQTT running on both Core and Photon with months of uptime.
I’m not publishing as often every mostly every 5 minutes or every minute but they have been going for 6+ months non stop.
So it’s not unreliable but it’s definitely depends on the application and needs testing around the specific use cases.
palitu
March 22, 2016, 9:39am
#5
Great to hear @mrOmatic , i have just gotten home from work, and it is still running fine, so that is something like 9hrs.
i only have one particle, so i dont have a lot of continuous uptime as i keep changing the program.
Assuming you are using the library in the webIDE - it seems like it can be stable enough for production.
There is plenty you can do to break the photon in you own code so testing and more testing but I don’t think the MQTT library is any less stable that the particle platform overall.
