MPU6050 Photon Issue
I am trying to connect my photon to the particle.io cloud with the following code. However, when I monitor the variables on the particle cli, they return a really large negative integer like -1231412412412412412421 for all three ax, ay, and az.
Can someone please help me. Thank you in advance.
Also, note that I am using the MPU6050 library.
I have wired my photon to MPU6050 properly:
D0 -> SDA
D1 -> SCL
VCC
GND
#include "application.h"
#include "MPU6050/MPU6050.h"
MPU6050 accelgyro;
int16_t ax, ay, az;
int16_t gx, gy, gz;
// setup() runs once, when the device is first turned on.
  // Put initialization like pinMode and begin functions here.
  Wire.begin();
  accelgyro.initialize();
  Particle.variable("ax", ax);
  Particle.variable("ay", ay);
  Particle.variable("az", az);
// loop() runs over and over again, as quickly as it can execute.
  // The core of your code will likely live here.
  accelgyro.getMotion6(&ax, &ay, &az, &gx, &gy, &gz);
AFAIK int16_t isn’t supported as Particle.variable - it should be int
Try that and let us know whether this cured the problem.
i have some working code for a mpu 9250, which is almost the same device as the 6050 with a magnetometer i can read raw data and pitch/roll etc. I found the module seems to give the same results at 5v as 3.3v powered from the spark core regulated output.
int16_t ax, ay, az;
int16_t gx, gy, gz; works in my code, the library is
MPU6050(ver 1.0.3)
#include <I2Cdev.h>
#include <MPU6050.h>
#include <math.h> //( im also doing some other manipulation of the data).
im not sure how to copy code and post it, if you need it, i think it would work on the photon
TOM
