Monitor One additional / accessories?
How do you resupply / get additional accessories for Monitor One?
Like perfboards, or even add Ethernet (RJ45 for peripherals)?
Unfortunately there isn't a separate SKU for the prototyping board at this time and it can't be purchased separately.
The expectation is that most users would end up fabricating their own Monitor One expansion card using a service like OshPark or JLCPCB rather than assembling multiple prototypes on the perfboard.
Since the headers are 0.1" you could also just use a blank perfboard and solder the male header pins on the bottom.
