AH NICE
should look something like that:
Your multimeter is tapping on ground and the other pin is the horizontal line
I think @AndyW gave a good idea on using a Solid State Relay, so we need:
The dashed lines is the
core side and solid line is the toy side
The 1k resistor is arbitrary but i think should be enough to trigger the SSR. The input will be a Digital pin. I can tell you the resistance value to use if we choose the SSR for the project
Looks like we are good to go and you can have it running like this weekend?!
