MLX90614 IR Temp sensor
Having an issue with using this sensor with my core.
Copied this code from https://community.spark.io/t/reading-i2c-ir-temperature-sensor/4529
#define LED_pin D7
#define slaveAddress 0x5A
void setup(){
  // An LED will blink to indicate when we have successfully read the temperature
  pinMode(LED_pin, OUTPUT);
  digitalWrite(LED_pin, LOW);
  Wire.begin();
  Wire.beginTransmission(slaveAddress);
void loop(){
  // Store the two relevant bytes of data for temperature
  byte dataLow = 0x00;
  byte dataHigh = 0x00;
  delay(10);
  Wire.write(0x07);    // This is the command to view object temperature in the sensor's RAM
  delay(10);
  Wire.endTransmission(false);
  delay(10);
  Wire.requestFrom(slaveAddress, 2);
  delay(10);
  while (Wire.available()){
    dataLow = Wire.read();
    dataHigh = Wire.read();
    digitalWrite(LED_pin, HIGH);    // Blink the LED to indicate a successful reading
  delay(10);
  double tempFactor = 0.02; // 0.02 degrees per LSB (measurement resolution of the MLX90614)
  double tempData = 0x0000; // zero out the data
  // This masks off the error bit of the high byte, then moves it left 8 bits and adds the low byte.
  tempData = (double)(((dataHigh & 0x007F) << 8) + dataLow);
  tempData = (tempData * tempFactor)-0.01;
  float celcius = tempData - 273.15;
  float fahrenheit = (celcius*1.8) + 32;
  Serial.print((String) fahrenheit);
  Serial.println("F");
delay(100);
Just getting a constant reading of 459.688019F - Using D0 & D1 for SDA & SCL
I’m pretty sure it isn’t the sensor as it works perfectly well with an Arduino.
Anybody have any clue what could be wrong?
@craiglockwood, do you have pull-up resistors on the two I2C lines? Are you using the device library I posted on my github? That library and example work fine.
Hi @peekay123
I am using pull up resistors (the sensor came on a board with resistors already wired up) - image below. Link to exact sensor: http://www.elechouse.com/elechouse/index.php?main_page=product_info&cPath=152_158&products_id=2241
I am using your library (thanks for writing it).
To be sure - I am using the following code:
#include "Adafruit_MLX90614.h"
#define LED_pin D7
void setup(){
  Wire.begin();
void loop(){
  delay(10);
  delay(10);
  delay(10);
  delay(10);
  delay(10);
delay(100);
With the Adafruit_MLX90614.cpp and Adafruit_MLX90614.H library files added.
I am fairly new to Spark stuff but been doing arduino stuff for some time. I may have made a stupid/simple error somewhere.
You can't - or better shall not - cast a float into a String!
Serial.println(fahrenheit, 2); will do the conversion - actually selecting the appropriate overload - and formating for two decimals for you.
To test this theory try setting your var like float fahrenheit = 12345.67; and see what your Serial.println((String)fahrenheit); will give you.
I don't think this cast to String does what you think it does--what happens if you just do this:
Serial.print(fahrenheit);
Thanks @ScruffR but that just gives me the same reading -459.69 to 2 DEC places. Still not the correct reading (reading not changing either)
Then I'd try dropping the (double) cast (or replace it for a (int16_t) cast) in this line too
No difference with either change. This electronics stuff is hard, eh? :grin:
@ScruffR Ah, yes - this does give a Serial out out of 12345.67 as expected
OK, this was a bit unexpected/counterintuitive for me.
Obviously (String) cast (better class cast operator) was designed cleverer than I thought :blush:
But obviously not only I fell for it (ey @bko ;-))
So we seem to have established that it was not your coding, but might rather be the sensor or its wiring.
Hmm - very strange. If I disconnect the SDA/SCL pins (D0 & D1) the serial output is still 459.69.
I suspect the Spark is faulty/broken. The sensor works fine on an Arduino.
Grrrr.
Gah! Tried with another Core and get exactly the same results.
Really not sure what the issue is here - it is obviously something I am doing wrong.
Since I’ve already damaged my reputation with my cast suggestions, I can’t do any more harm by asking other stupid questions :wink:
Are you powering the sensor off 3V3 or Vin?
To redeem myself I’ll have a look at Paul’s library, maybe I can spot a difference between it and your code.
@ScruffR powering from 3V3. Just tried with 10k pull up resistors too (thinking maybe the onboard pullups weren’t up to the job). Same results.
I bet I am doing something so wrong - been over everything countless times.
I might have missed it, or Wire.endTransmission()/Wire.requestFrom() does it implicitly, but I can only see one single call to Wire.beginTransmission() where Paul’s lib does a fresh begin each time he wants to get a 16bit reading.
This is how Paul (aka @peekay123 ) does it
uint16_t Adafruit_MLX90614::read16(uint8_t a) {
  uint16_t ret;
  Wire.beginTransmission(_addr); // start transmission to device
  Wire.write(a); // sends register address to read from
  Wire.endTransmission(false); // end transmission
  Wire.requestFrom(_addr, (uint8_t)3);// send data n-bytes read
  ret = Wire.read(); // receive DATA
  ret |= Wire.read() << 8; // receive DATA
  uint8_t pec = Wire.read();
  return ret;
Also note that he asks for three not two bytes in Wire.requestFrom(). Since you’re reading in a while(), you might even overwrite your first byte by reading the pec into the same var.
On the other hand: Since you’ve already included Paul’s lib, why do you not just use it?
Not sure what you mean by ‘why do you not just use it?’
OK - swapped out with a third Core and all works perfectly.
Some of these cores have been sitting at the bottom of a drawer for ages - possibly got damaged. All working well with a shiny new one.
Thank you for taking the time out - I really appreciate it.
You've got
But you're missing
Adafruit_MLX90614 mlx = Adafruit_MLX90614();
  mlx.begin();
  tmp = mlx.readObjectTempF()
Anyhow - good to hear that you've got it working.
But your Cores should not have died, just hanging around unused :confused:
Please @ScruffR and @craiglockwood, is it possible to use the same code for a photon? Because am experiencing a lot of problems with mine. I am trying to design a body worn temperature sensor using the MLX90614 IR sensor and a photon to transfer the data via wifi to my iPhone using the BLYNK APP. I have tried several times with different photons and it seems like whenever i flash the code to my photon, the photon stops working i.e. it connects to the WIFI but automatically turns off or remain frozen on cyan. I have become depressed in that I have destroyed three photons already with this process of flashing the code. Please below is the code am flashing, Am just a beginner in programming so please don’t laugh lol.
#include "blynk/blynk.h"
#include "OneWire/OneWire.h"
#include "i2cmaster/i2cmaster.h"
char auth[] = "9ca1cf2ce8d841dab213e26a8301550a";
//#include <Wire.h>
    Blynk.begin(auth);
    Serial.println("Adafruit MLX90614 test");
    mlx.begin();
    Blynk.run();
    Serial.print("Ambient = ");
    Serial.print(mlx.readAmbientTempC());
    Serial.print("*C\tObject = ");
    Serial.print(mlx.readObjectTempC());
    Serial.println("*C");
    Blynk.virtualWrite(V1, mlx.readAmbientTempC());
    Blynk.virtualWrite(V2, mlx.readObjectTempC());
    //Serial.print("Ambient = "); Serial.print(mlx.readAmbientTempF());
    //Serial.print("*F\tObject = "); Serial.print(mlx.readObjectTempF());
    //Serial.println("*F");
    //Blynk.virtualWrite(V1, mlx.readAmbientTempF());
    //Blynk.virtualWrite(V2, mlx.readObjectTempF());
    Serial.println();
    delay(500);
Please help me out to indicate if am doing anything wrong and your help will greatly be appreciated. Thanks
