Mirror the Charge Status LED?
Is there a way to mirror the red charge status LED to a pin on the Electron? I want to have my LED external to the project box and I just can’t seem to find out if this possible. I assume it is as there’s a system in place to mirror the RGB LED.
Hi @hugh,
I used this link to get the 'state' of the battery charging, it works well.
Using the state - you could then set flags to act in the same way.
Thanks @Cameron! That does appear to be what I’m looking for.
Thanks for the help!
