Hello Everyone - First post.
I’ve been using Particle Photons for a while with simple projects like temperature sensing, servo control, etc. I have a sorting machine that is currently running on a Arduino Nano and wanted to port it Particle Photon to be able to monitor the machine conditions remotely.
The code below verifies fine and flashes to the Photon fine but I have issues with the Photon losing connectivity to the Cloud (Periodic Green flashing). I suspect that it’s due to the numerous delay statements. I need the delays for the machine to function properly. Any suggestions?
--------------------------------CODE--------------------------------
#include <LiquidCrystal_I2C_Spark.h>
#include <Wire.h>
// initialize the library with the numbers of the interface pins
LiquidCrystal_I2C lcd(0x27,16,2);
Servo servo1;
Servo servo2;
* Input pins for the color sensor & servos
const int s0 = D5;
const int s1 = D4; //Dispenser Servo
const int s2 = A4; //Color Sensing Servo
const int s3 = A5;
const int out = D2;
const int servo1_pin = D6;
const int servo2_pin = D7;
* Vars
const int tot_colors = 5; // 4 colors + 1 empty "color"
const int rep = 8; // repeat xx color reads
const int d = 5; // add range of XX to the read
//Added 10/29/18 Set Integers for Color and Total Count at Zero
int c1Total = 0;
int c2Total = 0;
int c3Total = 0;
int c4Total = 0;
int c5Total = 0;
int totTotal = 0;
volatile unsigned de = 1; // delay servo movement
* Servo positions
* Set the positions in degree where the servo
* has to stop to drop the ball
const int s1pos[] = { 125, 87, 55 ,0 ,180};
const int s2pos[] = { 180, 34, 58, 79, 102}; // first item = unknown color was 180,34,58,80,104
int colors_found = 0;
unsigned long red, green, blue = 0;
typedef struct{
int red;
int green;
int blue;
} colors_type;
colors_type colors[tot_colors]; // length of array: sizeof(colors)/sizeof(colors_type)
servo1.attach(servo1_pin);
servo2.attach(servo2_pin);
pinMode(s0, OUTPUT);
pinMode(s1, OUTPUT);
pinMode(s2, OUTPUT);
pinMode(s3, OUTPUT);
pinMode(out, INPUT);
digitalWrite(s0, HIGH);
digitalWrite(s1, HIGH);
// initialize the lcd
lcd.init();
lcd.backlight();
lcd.begin(16, 2);
//Boot Message
lcd.print("Saturn Candy Inc");
lcd.setCursor(0,1);
lcd.print("Plant 2, Mach 12");
delay(100); //ADDED DELAY 3/28/19 WAS 200
lcd.clear();
//Product Message
lcd.setCursor(0,0);
lcd.print("Smart Connected");
lcd.setCursor(0, 1);
lcd.print("Candy Machine");
lcd.clear();
//Initialize Machine
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Initializing");
lcd.setCursor(0,1);
lcd.print("Sorting Machine");
lcd.clear();
//Begin Calibration
lcd.setCursor(0,0);
lcd.print("Begin Calibration");
lcd.setCursor(0,1);
lcd.print("Now");
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Green Blue Purple");
lcd.setCursor(0,1);
lcd.print("Pink Orange");
lcd.clear();
initCalibration();
// Loop multiple functions
void loop(){
load();
pos();
readColor();
checkColor();
void initCalibration(){
gopos(0,2); // empty the loader for calibration
delay(100); // //ADDED DELAY 3/28/19 WAS 200
eject(); //delay(500);
pos();
delay(150); // Original delay was 700
//Read Empty Color
readColor();
colors[0].red = red;
colors[0].green = green;
colors[0].blue = blue;
//Serial.println("Empty: ");
//Serial.println(String(red) + " "+ String(green) + " " + String(blue));
void checkColor(){
for (int i = 0 ; i < 5 ; i++) { //5
// Serial.println(String(i) + ": "+ String(colors[i].red) + " " + String(colors[i].green) + " "+ String(colors[i].blue));
if (
inRange(red, colors[i].red - d, colors[i].red + d) &&
inRange(green, colors[i].green - d, colors[i].green + d) &&
inRange(blue, colors[i].blue - d, colors[i].blue + d)
// Color match!
if (i==0) {
delay(100); // Original Delay was 100
// eject();
return;
Serial.println("Matched Color " + String(i));
// lcd.setCursor(0,0);
// lcd.print("Matched Color " + String(i));
gopos(i,2);
// Increment total pieces sorted
++totTotal;
// Increment Total per Color
if (i==1)
c1Total++ ;
Serial.println("Total Sorted: " + String(totTotal));
Serial.println("Color 1: " + String(c1Total));
lcd.setCursor(0,0);
lcd.clear();
lcd.print("Tot:" + String(totTotal) +" C1 Tot:" + String(c1Total));
else if (i==2)
c2Total++ ;
Serial.println("Color 2: " + String(c2Total));
lcd.setCursor(0,0);
lcd.clear();
lcd.print("Tot:" + String(totTotal) +" C2 Tot:" + String(c2Total));
else if (i==3)
c3Total++ ;
Serial.println("Color 3: " + String(c3Total));
lcd.setCursor(0,0);
lcd.clear();
lcd.print("Tot:" + String(totTotal) +" C3 Tot:" + String(c3Total));
else if (i==4)
c4Total++ ;
Serial.println("Color 4: " + String(c4Total));
lcd.setCursor(0,0);
lcd.clear();
lcd.print("Tot:" + String(totTotal) +" C4 Tot:" + String(c4Total));
eject();
return;
if (colors_found < tot_colors){ // Color not found, adding color to the array
colors_found++;
Serial.print("New color found! Total Colors Found: ");
Serial.print(colors_found);
lcd.setCursor(0,0);
lcd.print("Colors Found: ");
lcd.print(colors_found);
delay(100);
if (colors_found >= 5){ //5
gopos(0,2);
delay(100); //ADDED DELAY 10/9 WAS 200
eject();
return;
gopos(colors_found,2 );
eject();
colors[colors_found].red = red;
colors[colors_found].green = green;
colors[colors_found].blue = blue;
return;
gopos(0,2);
delay(100); //ADDED DELAY 10/9 Was 200
totTotal++;
c5Total++ ;
Serial.println("Color 5: " + String(c5Total));
lcd.setCursor(0,0);
lcd.clear();
lcd.print("Tot:" + String(totTotal) +" C5 Tot:" + String(c5Total));
eject();
void readColor(){
red = green = blue = 0;
for (int i = 1; i <= rep ; i++) {
digitalWrite(s2, LOW);
digitalWrite(s3, LOW);
red += pulseIn(out, digitalRead(out) == HIGH ? LOW : HIGH);
digitalWrite(s3, HIGH);
blue += pulseIn(out, digitalRead(out) == HIGH ? LOW : HIGH);
digitalWrite(s2, HIGH);
green += pulseIn(out, digitalRead(out) == HIGH ? LOW : HIGH);
delay(3);
red = red / rep;
blue = blue / rep;
green = green / rep;
int sum = red + green + blue;
red = red * 100 / sum;
blue = blue * 100 / sum;
green = green * 100/ sum;
// Bottom of LCD Display, current sensed RGB values
Serial.println(" ");
Serial.println(String(red) + " " + String(green) + " " + String(blue) + " ");
lcd.setCursor(0,1);
lcd.println("Color: " + String(red) + " " + String(green) + " " + String(blue) + " ");
void load() {
gopos(0,1);
void pos() {
gopos(1,1);
void eject() {
gopos(2,1);
bool inRange(int val, int minimum, int maximum) {
return ((minimum <= val) && (val <= maximum));
void gopos(int p, int z){
int r = (z == 1) ? servo1.read() : servo2.read();
int go = (z == 1) ? s1pos[p] : s2pos[p];
if (r == go ) return;
if (go > r){
for (int s = r; s <= go ;s++){
if (z == 1) servo1.write(s);
if (z == 2) servo2.write(s);
delay(de);
else{
for (int s = r; s >= go ; s--){
delay(de);
delay(10); //ADDED DELAY 3/28/19 WAS 90
