I attempted a search and could not found where this topic item is supported (Memory Usage for Atom IDE). The closest answer I found was from @ScruffR in this thread, but alas the "particle serial identify" cite does not return usage:
Is this just buried to where I can't see it or are there plans to get this integrated like the Web IDE? I'm not able to build my project in the Web IDE, either (library complications).
And while on the subject, how would a memory usage limit violation manifest in the Atom IDE?
I guess you’ll just get a can’t compile message when the limit is hit - but Dev is not my environment
You can file an “issue” here to request that feature https://github.com/spark/particle-dev/issues
