Measuring temperature with a thermistor 10k
I have a thermistor 10k
using 3.3v
i’m testing the sample code of thermistor-library but when I click verify to build bin file I receive this errors:
I don’t understand this errors and can’t find a solution.
In file included from ../inc/spark_wiring.h:29:0,
from ../inc/application.h:29,
from thermistor-library/thermistor-library.h:2,
from example.cpp:1:
../../core-common-lib/SPARK_Firmware_Driver/inc/config.h:12:2: warning: #warning "Defaulting to Release Build" [-Wcpp]
example.cpp: In function 'void loop()':
example.cpp:25:37: error: no matching function for call to 'Thermistor::getTempC()'
example.cpp:25:37: note: candidate is:
In file included from example.cpp:1:0:
thermistor-library/thermistor-library.h:18:9: note: float Thermistor::getTempC(bool)
float getTempC(bool smooth);
thermistor-library/thermistor-library.h:18:9: note: candidate expects 1 argument, 0 provided
make: *** [example.o] Error 1
Error: Could not compile. Please review your code.
full code:
    #include "thermistor-library/thermistor-library.h"
    // Analog pin the thermistor is connected to
    int thermPin = A1;
    // Voltage divider resistor value
    int thermRes = 10000;
    // Configure the Thermistor class
    Thermistor Thermistor(thermPin, thermRes);
    	// Start Serial output
    	// Initialize the Thermistor class
    	Thermistor.begin();
    	// Print temperature in degrees Celsius
    	Serial.print("Celsius: ");
    	Serial.println(Thermistor.getTempC());
    	// Wait 1 second
    	delay(1000);
@wgbartley contributed this so he might have some idea :wink:
The error message is quite explicit
You have to provide a bool as parameter for getTemp(), you don't provide any parameter.
Sure, the sample should run out the box, but some minimum understanding of the matter might be required still.
I wrote that earlier but seems like in the .cpp file there’s a default argument but of course, adding the argument when calling should resolve the issue :wink:
The default parameter needs to be set in the header file in order to be known in the including program.
In a closed source library you would only have the header file and you (the user) wouldn’t know anything about the default parameter either.
PR sent: https://github.com/wgbartley/spark-thermistor-library/pull/1
PR merged!
Thanks @kennethlimcp!!!
Awesome! @rbbahia, once the new version is reimported to Web IDE, it should work without a default arguement :wink:
I tried now bute get this error:
from example.cpp:1:
Either you do what @kennethlimcp said, or what I said earlier (before the new version)
It's exactly the same error as the one I've explained above already!
