Making a BLE singleton
Hi All,
I am currently making a singleton class using the application note generator to house the Bluetooth code in my application.
I am having difficulty knowing where to place the following code:
const BleUuid serviceUuid("<my service id>");
BleCharacteristic emailCharacteristic("Email", BleCharacteristicProperty::WRITE, BleUuid("3b2c9a89-cd44-453f-a76e-0e5ef9598e6b"), serviceUuid, &Bluetooth::onDataReceived, NULL);
My onDataReceived function is in my Bluetooth.cpp file (which was generated with the application note generator),
void Bluetooth::onDataReceived(const uint8_t *data, size_t len, const BlePeerDevice &peer, void *context){
Where should I place the BleCharacteristic emailCharacteristic(...) ?
Is this the same issue when trying to initialise particle functions within a singleton where I need to place &Bluetooth:: before onDataReceived ?
Apologies,
I found the solution here I think:
I'm pretty sure the above is the solution, but still having an issue.
I have defined the following in my singleton .h file
void onDataReceived(const uint8_t *data, size_t len, const BlePeerDevice &peer);
static void onDataReceivedStatic(const uint8_t* data, size_t len, const BlePeerDevice& peer, void* context);
as per Rick's example.
But where should I define the following characteristic. If defined in the public section in the singleton .h file, then it throws errors. If I define it at the top of my singleton .cpp file then I have to reference the onDataReceivedStatic as Bluetooth::onDataReceivedStatic but then I can no longer use this as the last argument in the BleCharacteristic.
Does anyone know where I am going wrong?
BleCharacteristic emailCharacteristic("Email", BleCharacteristicProperty::WRITE, BleUuid("3b2c9a89-cd44-453f-a76e-0e5ef9598e6b"), serviceUuid, onDataReceived, this);
Ok I got there in the end. I defined the BleCharacteristic in my singleton .cpp file as the following:
BleCharacteristic emailCharacteristic("Email", BleCharacteristicProperty::WRITE, BleUuid("3b2c9a89-cd44-453f-a76e-0e5ef9598e6b"), serviceUuid, &bluetoothHandler::onDataReceivedStatic, &bluetoothHandler::instance());
So I handed in &bluetoothHandler::instance() in place of this.
