LoRa FANET with RH_RF95.h and RFM95W
Hello, I am making some experiment to work with FANET+ network. I would like to publish wind data from a Photon connected anemometer to the FANET network (is a LoRa application for paragliding devices).
I have two devices working on this network (they are talking togheter) and I would like to add a custom Photon with RFM95W transceiver.
This is the FANET specification:
868.2Mhz
Syncword 0xF1
250kHz Bandwidth
Spreading Factor 7
ExplicitHeader: Coding Rate CR 5-8/8 (depending on #neighbors), CRC for Payload
This my code, it compile, it runs (no error on RF95 init) but I can’t see any raw data.
#include <RH_RF95.h>
#include <SPI.h>
#define RFM95_RST     1
#define RFM95_CS      6
#define RFM95_INT     2
#define SERIAL_DEBUG
// Singleton instance of the radio driver
RH_RF95 rf95(RFM95_CS, RFM95_INT);
#define LED 7
SYSTEM_THREAD(ENABLED);
  delay(5000);
  pinMode(LED, OUTPUT);
  pinMode(RFM95_RST, OUTPUT);
  digitalWrite(RFM95_RST, HIGH);
  Serial.begin(115200);
  while (!Serial) {
    delay(1);
  delay(100);
  Serial.println("Feather LoRa RX Test!");
  // manual reset
  digitalWrite(RFM95_RST, LOW);
  delay(10);
  delay(10);
  while (!rf95.init()) {
    Serial.println("LoRa radio init failed");
    Serial.println("Uncomment '#define SERIAL_DEBUG' in RH_RF95.cpp for detailed debug info");
    while (1);
  Serial.println("LoRa radio init OK!");
  // Defaults after init are 434.0MHz, modulation GFSK_Rb250Fd250, +13dbM
  if (!rf95.setFrequency(RF95_FREQ)) {
    Serial.println("setFrequency failed");
    while (1);
  Serial.print("Set Freq to: "); Serial.println(RF95_FREQ);
  rf95.setSignalBandwidth(250E3);
  rf95.setSpreadingFactor(7);
  rf95.setCodingRate4(8);
  rf95.setPreambleLength(12);
  rf95.setPayloadCRC(1);
  // The default transmitter power is 13dBm, using PA_BOOST.
  // If you are using RFM95/96/97/98 modules which uses the PA_BOOST transmitter pin, then
  // you can set transmitter powers from 5 to 23 dBm:
  rf95.setTxPower(23, false);
  if (rf95.available())
    // Should be a message for us now
    uint8_t buf[RH_RF95_MAX_MESSAGE_LEN];
    uint8_t len = sizeof(buf);
    if (rf95.recv(buf, &len))
      digitalWrite(LED, HIGH);
      RH_RF95::printBuffer("Received: ", buf, len);
      Serial.print("Got: ");
      Serial.println((char*)buf);
       Serial.print("RSSI: ");
      Serial.println(rf95.lastRssi(), DEC);
      // Send a reply
      uint8_t data[] = "And hello back to you";
      rf95.send(data, sizeof(data));
      rf95.waitPacketSent();
      Serial.println("Sent a reply");
      digitalWrite(LED, LOW);
    else
      Serial.println("Receive failed");
Where I am wrong? How can I deal with it?
@not103 ,
Did you
-define RF95_FREQ somewhere’s?
-double check wiring?
FREQ was defined, after paste the code I probbly accidentally delete it with an unnecessary comment.
Just after #define LED 7 there is
#define RF95_FREQ 868.2
Wiring seems ok. Same RFM95W board connected to an ESP8266 works, it connect with the above LoRa implementation.
This is a printout of RFM95W registry:
1: 81
6: D9
7: 0
8: 0
9: 88
A: 9
B: 2B
C: 20
D: 0
E: 0
F: 0
10: 0
11: 0
12: 0
13: 0
14: 0
15: 0
16: 0
17: 0
18: 10
19: 0
1A: 0
1B: 0
1C: 0
1D: 88
1E: 74
1F: 64
20: 0
21: 8
22: 1
23: FF
24: 0
25: 0
26: 4
27: 0
39: F1
42: 12
@not103
hmmm, can't see any other problems...
However, I have been using
sendtoWait
(RHReliableDiagram) successfully rather than your use of
You might look at my gists at bprobbins’s gists · GitHub
Well I would like to start trying to receive a message (the two devices sends broadcast message) but I can’t get anything.
I'd start by trying the default modem settings:
rf95.setModemConfig(RH_RF95::Bw125Cr45Sf128 );
on two devices, then if that works try out your earlier setting one by one.
I actually never could successfully get anything but the default settings to work
The devices I have aren’t customizable, they only works with configuration with these specs:
868.2Mhz
Syncword 0xF1
250kHz Bandwidth
Spreading Factor 7
I think the recommended library to use is RF9X-RK. Did you try that?
@not103
Not sure what specific thing did it, but with a few changes, it works for me:
First, added the RF9X-RK library as above.
Second, I apparently wired the feather radio differently, so changed those defines - see code below:
Third, eliminated the initial delay - caused panic in my photons for some reason, and it’s unnecessary.
Fourth, set up a random seed to provide a random delay in loop so that the two devices don’t get in a race issue or sync lock.
Fifth, put a startup message at the end of setup in one device.
I also reduced txpower since I had my two photons side by side
Photon1:
#include <RF9X-RK.h>
#include <SPI.h>
#define RFM95_RST     1
#define RFM95_CS      6
#define RFM95_INT     2
#define RFM95_CS  A2
#define RFM95_RST 4
#define RFM95_INT D2
#define LED 7
 #define RF95_FREQ 915.0
 // delay(5000);
  while (!Serial) {
    delay(1);
  delay(100);
  // manual reset
  delay(10);
  delay(10);
    while (1);
    while (1);
  rf95.setTxPower(6, false);
    randomSeed(analogRead(0));
    uint8_t data2[] = "Start Message";
    rf95.send(data2, sizeof(data2));
 delay(random(1000, 2000));
      // Send a reply
    else
And Photon 2:
#include <SPI.h>
#define RFM95_RST     1
#define RFM95_CS      6
#define RFM95_INT     2
#define RFM95_CS  A2
#define RFM95_RST 4
#define LED 7
 //delay(5000);
  while (!Serial) {
    delay(1);
  delay(100);
  // manual reset
  delay(10);
  delay(10);
    while (1);
    while (1);
      // Send a reply
    else
