Before I start, please forgive my lack of knowledge - I have been trying to dig up the coding I learnt at uni many years ago but even then I found it confusing! I am trying though.
I have decided to follow this tutorial I found online to make some Global Synchronised touch lamps. Here.
I have managed to get 2 lights set up and synchronised and I ‘think’ doing what they are supposed to be doing. The problem is it’s not exactly what I was hoping for…
What I am ideally wanting is for each light to have it’s own colour. So for example, whenever I touch my light - all lights in the system turn green. Then if my mum touches her light all lights turn purple, and if I add others they will have their own colour. Once I have pressed my lamp and my colour is showing I can’t change it until another colour appears.
I also don’t really want there to be a different result depending on how long the lamp is touched for (which I ‘think’ is part of the code).
Is anyone able to offer advice on what changes I can make to the code to enable this to happen - or indeed point me in the direction of which bits of code I should be looking at!
The full code is shown on this thread here incase my attempts to paste it below fail miserably.
Thank you
* Project: touch_light
* Description: A touch light that syncs with other touch lights. Adapted from
* http://www.instructables.com/id/Networked-RGB-Wi-Fi-Decorative-Touch-Lights/
* Author: Patrick Blesi
* Date: 2017-12-09
#include "neopixel.h"
#include "application.h"
#include "wifi_creds.h"
// CONFIGURATION SETTINGS START
// DEBUG SETTINGS:
#define D_SERIAL false
#define D_WIFI false
String touchEventName = "touch_event";
#define NUM_PARTICLES 2 // number of touch lights in your group
// Number each Filimin starting at 1.
String particleId[] = {
"", // 0
"44002a000947373334323234", // Mum
"2d0047001247353236343034", // Me
int particleColors[] = {
0, // Green
90, // Magenta
170, // Blue
79, // Orange
131 // Purple
// TWEAKABLE VALUES FOR CAP SENSING. THE BELOW VALUES WORK WELL AS A STARTING PLACE:
// BASELINE_VARIANCE: The higher the number the less the baseline is affected by
// current readings. (was 4)
#define BASELINE_VARIANCE 512.0
// SENSITIVITY: Integer. Higher is more sensitive (was 8)
#define SENSITIVITY 8
// BASELINE_SENSITIVITY: Integer. A trigger point such that values exceeding this point
// will not affect the baseline. Higher values make the trigger point sooner. (was 16)
#define BASELINE_SENSITIVITY 16
// SAMPLE_SIZE: Number of samples to take for one reading. Higher is more accurate
// but large values cause some latency.(was 32)
#define SAMPLE_SIZE 512
#define SAMPLES_BETWEEN_PIXEL_UPDATES 32
#define LOOPS_TO_FINAL_COLOR 150
const int minMaxColorDiffs[2][2] = {
{5,20}, // min/Max if color change last color change from same touch light
{50,128} // min/Max if color change last color change from different touch light
// END VALUE, TIME
// 160 is approximately 1 second
const long envelopes[6][2] = {
{0, 0}, // NOT USED
{255, 30}, // ATTACK
{200, 240}, // DECAY
{200, 1000}, // SUSTAIN
{150, 60}, // RELEASE1
{0, 1000000} // RELEASE2 (65535 is about 6'45")
#define PERIODIC_UPDATE_TIME 5 // seconds
#define COLOR_CHANGE_WINDOW 10 // seconds
// CONFIGURATION SETTINGS END
// STATES:
#define ATTACK 1
#define DECAY 2
#define SUSTAIN 3
#define RELEASE1 4
#define RELEASE2 5
#define OFF 6
#define LOCAL_CHANGE 0
#define REMOTE_CHANGE 1
#define END_VALUE 0
#define TIME 1
#define tEVENT_NONE 0
#define tEVENT_TOUCH 1
#define tEVENT_RELEASE 2
String eventTypes[] = {
"None",
"Touch",
"Release"
int sPin = D4;
int rPin = D3;
// NEOPIXEL
#define PIXEL_PIN D2
#define PIXEL_COUNT 24
#define PIXEL_TYPE WS2812B
// STATE
unsigned char myId = 0;
int currentEvent = tEVENT_NONE;
int eventTime = Time.now();
int eventTimePrecision = random(INT_MAX);
int initColor = 0;
int currentColor = 0; // 0 to 255
int finalColor = 0; // 0 to 255
int lastLocalColorChangeTime = Time.now();
int initBrightness = 0; // 0 to 255
int currentBrightness = 0; // 0 to 255
unsigned char prevState = OFF;
unsigned char state = OFF;
unsigned char lastColorChangeDeviceId = 1;
long loopCount = 0;
long colorLoopCount = 0;
int lastPeriodicUpdate = Time.now();
// timestamps
unsigned long tS;
volatile unsigned long tR;
// reading and baseline
float tBaseline;
double tDelayExternal = 0;
double tBaselineExternal = 0;
Adafruit_NeoPixel strip = Adafruit_NeoPixel(PIXEL_COUNT, PIXEL_PIN, PIXEL_TYPE);
#ifdef WIFI_CREDENTIALS_SPECIFIED
SYSTEM_MODE(SEMI_AUTOMATIC);
#endif
setupWifi();
#endif
Particle.subscribe(touchEventName, handleTouchEvent, MY_DEVICES);
if (D_SERIAL) Serial.begin(9600);
if (D_WIFI) {
Particle.variable("tDelay", &tDelayExternal, DOUBLE);
Particle.variable("tBaseline", &tBaselineExternal, DOUBLE);
strip.begin();
strip.show(); // Initialize all pixels to 'off'
pinMode(sPin, OUTPUT);
attachInterrupt(rPin, touchSense, RISING);
myId = getMyId(particleId, NUM_PARTICLES);
flashWhite(&strip);
// Calibrate touch sensor- Keep hands off!!!
tBaseline = touchSampling(); // initialize to first reading
if (D_WIFI) tBaselineExternal = tBaseline;
traverseColorWheel(&strip);
fade(&strip);
int touchEvent = touchEventCheck();
if (touchEvent == tEVENT_NONE) {
// Publish periodic updates to synchronize state
bool touchedBefore = currentEvent != tEVENT_NONE;
if (lastPeriodicUpdate < Time.now() - PERIODIC_UPDATE_TIME && touchedBefore) {
publishTouchEvent(currentEvent, finalColor, eventTime, eventTimePrecision);
return;
// Random eventTimePrecision prevents ties with other
// server events. This allows us to determine dominant
// color in the event of ties.
setEvent(touchEvent, Time.now(), random(INT_MAX));
if (D_SERIAL) Serial.println(eventTypes[touchEvent]);
if (touchEvent == tEVENT_TOUCH) {
int newColor = generateColor(finalColor, prevState, lastColorChangeDeviceId);
setColor(newColor, prevState, myId);
changeState(ATTACK, LOCAL_CHANGE);
// Setup functions
// Functions used during setup
void setupWifi() {
WiFi.on();
WiFi.disconnect();
WiFi.clearCredentials();
int numWifiCreds = sizeof(wifiCreds) / sizeof(*wifiCreds);
for (int i = 0; i < numWifiCreds; i++) {
credentials creds = wifiCreds[i];
WiFi.setCredentials(creds.ssid, creds.password, creds.authType, creds.cipher);
WiFi.connect();
waitUntil(WiFi.ready);
Particle.connect();
int getMyId(String particleId[], int numParticles) {
int id = 0;
for (int i = 1; i <= numParticles; i++) {
if (!particleId[i].compareTo(Particle.deviceID())) {
id = i;
break;
return id;
void flashWhite(Adafruit_NeoPixel* strip) {
int numPixels = strip->numPixels();
for (byte j = 0; j < numPixels; j++) {
strip->setPixelColor(j, 255, 255, 255);
strip->show();
delay(250);
strip->setPixelColor(j, 0, 0, 0);
strip->show();
delay(250);
void traverseColorWheel(Adafruit_NeoPixel* strip) {
for (int i = 0; i < 256; i++) {
uint32_t color = wheelColor(i, 255);
strip->setPixelColor(j, color);
strip->show();
delay(1);
void fade(Adafruit_NeoPixel* strip) {
for (int j = 255; j >= 0; j--) {
uint32_t color = wheelColor(255, j);
for (byte k = 0; k < numPixels; k++) {
strip->setPixelColor(k, color);
strip->show();
delay(1);
// touch sampling
// sample touch sensor SAMPLE_SIZE times and get average RC delay [usec]
long touchSampling() {
long tDelay = 0;
int mSample = 0;
for (int i = 0; i < SAMPLE_SIZE; i++) {
if (!(i % SAMPLES_BETWEEN_PIXEL_UPDATES)) {
updateState();
pinMode(rPin, OUTPUT); // discharge capacitance at rPin
digitalWrite(sPin,LOW);
digitalWrite(rPin,LOW);
pinMode(rPin,INPUT); // revert to high impedance input
// timestamp & transition sPin to HIGH and wait for interrupt in a read loop
tS = micros();
tR = tS;
digitalWrite(sPin,HIGH);
do {
// wait for transition
} while (digitalRead(rPin)==LOW);
// accumulate the RC delay samples
// ignore readings when micros() overflows
if (tR > tS) {
tDelay = tDelay + (tR - tS);
mSample++;
// calculate average RC delay [usec]
if ((tDelay > 0) && (mSample > 0)) {
tDelay = tDelay/mSample;
} else {
tDelay = 0; // this is an error condition!
if (D_SERIAL) Serial.println(tDelay);
if (D_WIFI) tDelayExternal = tDelay;
// autocalibration using exponential moving average on data below specified point
if (tDelay < (tBaseline + tBaseline/BASELINE_SENSITIVITY)) {
tBaseline = tBaseline + (tDelay - tBaseline)/BASELINE_VARIANCE;
return tDelay;
// Touch UI
// ISR for touch sensing
void touchSense() {
tR = micros();
// touch event check
// check touch sensor for events:
// tEVENT_NONE no change
// tEVENT_TOUCH sensor is touched (Low to High)
// tEVENT_RELEASE sensor is released (High to Low)
int touchEventCheck() {
int touchSense; // current reading
static int touchSenseLast = LOW; // last reading
static unsigned long touchDebounceTimeLast = 0; // debounce timer
int touchDebounceTime = 50; // debounce time
static int touchNow = LOW; // current debounced state
static int touchLast = LOW; // last debounced state
int tEvent = tEVENT_NONE; // default event
// read touch sensor
long tReading = touchSampling();
// touch sensor is HIGH if trigger point some threshold above Baseline
if (tReading > (tBaseline + tBaseline / SENSITIVITY)) {
touchSense = HIGH;
} else {
touchSense = LOW;
// debounce touch sensor
// if state changed then reset debounce timer
if (touchSense != touchSenseLast) {
touchDebounceTimeLast = millis();
touchSenseLast = touchSense;
// accept as a stable sensor reading if the debounce time is exceeded without reset
if (millis() > touchDebounceTimeLast + touchDebounceTime) {
touchNow = touchSense;
// set events based on transitions between readings
if (!touchLast && touchNow) {
tEvent = tEVENT_TOUCH;
if (touchLast && !touchNow) {
tEvent = tEVENT_RELEASE;
// update last reading
touchLast = touchNow;
return tEvent;
void setEvent(int event, int timeOfEvent, int timePrecision) {
currentEvent = event;
eventTime = timeOfEvent;
eventTimePrecision = timePrecision;
void handleTouchEvent(const char *event, const char *data) {
String eventData = String(data);
int deviceIdEnd = eventData.indexOf(',');
int deviceId = eventData.substring(0, deviceIdEnd).toInt();
int eventEnd = eventData.indexOf(',', deviceIdEnd + 1);
int serverEvent = eventData.substring(deviceIdEnd + 1, eventEnd).toInt();
int colorEnd = eventData.indexOf(',', eventEnd + 1);
int serverColor = eventData.substring(eventEnd + 1, colorEnd).toInt();
int eventTimeEnd = eventData.indexOf(',', colorEnd + 1);
int serverEventTime = eventData.substring(colorEnd + 1, eventTimeEnd).toInt();
int serverEventTimePrecision = eventData.substring(eventTimeEnd + 1).toInt();
if (false) {
String response = "deviceId: " + String(deviceId) + " " +
"serverEvent: " + String(serverEvent) + " " +
"serverColor: " + String(serverColor) + " " +
"localEventTime: " + String(eventTime) + " " +
"serverEventTime: " + String(serverEventTime) + " " +
"serverEventTimePrecision: " + String(serverEventTimePrecision);
Particle.publish("touch_response", response, 61, PRIVATE);
if (deviceId == myId) return;
if (serverEventTime < eventTime) return;
// Race condition brought colors out of sync
if (
serverEventTime == eventTime &&
serverEventTimePrecision == eventTimePrecision &&
serverColor != finalColor &&
myId < deviceId
setColor(serverColor, prevState, deviceId);
changeState(ATTACK, REMOTE_CHANGE);
return;
if (serverEventTime == eventTime && serverEventTimePrecision <= eventTimePrecision) return;
// Valid remote update
setEvent(serverEvent, serverEventTime, serverEventTimePrecision);
if (serverEvent == tEVENT_TOUCH) {
} else {
changeState(RELEASE1, REMOTE_CHANGE);
void setColor(int color, unsigned char prevState, unsigned char deviceId) {
lastColorChangeDeviceId = deviceId;
if (prevState == OFF) currentColor = color;
initColor = currentColor;
finalColor = color;
colorLoopCount = 0;
if (D_SERIAL) {
Serial.print("get Color From Server Final color: ");
Serial.print(initColor);
Serial.print(", ");
Serial.print(finalColor);
Serial.print(", ");
int generateColor(int currentFinalColor, unsigned char prevState, int lastColorChangeDeviceId) {
int color = 0;
int now = Time.now();
Serial.println("generating color...");
if (prevState == OFF || lastLocalColorChangeTime < now - COLOR_CHANGE_WINDOW) {
color = particleColors[myId];
} else {
bool foreignId = (lastColorChangeDeviceId != myId);
int minChange = minMaxColorDiffs[foreignId][0];
int maxChange = minMaxColorDiffs[foreignId][1];
int direction = random(2) * 2 - 1;
int magnitude = random(minChange, maxChange + 1);
color = currentFinalColor + direction * magnitude;
color = (color + 256) % 256;
// color = 119; // FORCE A COLOR
lastLocalColorChangeTime = now;
if (D_SERIAL) { Serial.print("final color: "); Serial.println(finalColor); }
return color;
void changeState(unsigned char newState, int remoteChange) {
prevState = state;
state = newState;
initBrightness = currentBrightness;
loopCount = 0;
if (D_SERIAL) { Serial.print("state: "); Serial.println(newState); }
if (remoteChange) return;
if (newState == ATTACK || newState == RELEASE1) {
void publishTouchEvent(int event, int color, int time, int timePrecision) {
String response = String(myId) + "," +
String(event) + "," +
String(color) + "," +
String(time) + "," +
String(timePrecision);
Particle.publish(touchEventName, response, 60, PRIVATE);
void updateState() {
switch (state) {
case ATTACK:
if (loopCount >= envelopes[ATTACK][TIME]) {
changeState(DECAY, LOCAL_CHANGE);
break;
case DECAY:
if ((loopCount >= envelopes[DECAY][TIME]) || (currentEvent == tEVENT_RELEASE)) {
changeState(SUSTAIN, LOCAL_CHANGE);
break;
case SUSTAIN:
if ((loopCount >= envelopes[SUSTAIN][TIME]) || (currentEvent == tEVENT_RELEASE)) {
changeState(RELEASE1, LOCAL_CHANGE);
break;
case RELEASE1:
if (loopCount >= envelopes[RELEASE1][TIME]) {
changeState(RELEASE2, LOCAL_CHANGE);
break;
case RELEASE2:
if (loopCount >= envelopes[RELEASE2][TIME]) {
changeState(OFF, LOCAL_CHANGE);
break;
currentBrightness = getCurrentBrightness(state, initBrightness, loopCount);
if (currentColor != finalColor) {
currentColor = getCurrentColor(finalColor, initColor, colorLoopCount);
uint32_t colorAndBrightness = wheelColor(currentColor, currentBrightness);
updateNeoPixels(colorAndBrightness);
loopCount++;
colorLoopCount++;
int getCurrentBrightness(unsigned char state, int initBrightness, int loopCount) {
if (state == OFF) return 0;
int brightnessDistance = envelopes[state][END_VALUE] - initBrightness;
int brightnessDistanceXElapsedTime = brightnessDistance * loopCount / envelopes[state][TIME];
return min(255, max(0, initBrightness + brightnessDistanceXElapsedTime));
int getCurrentColor(int finalColor, int initColor, int colorLoopCount) {
if (colorLoopCount > LOOPS_TO_FINAL_COLOR) return finalColor;
int colorDistance = calcColorChange(initColor, finalColor);
int colorDistanceXElapsedTime = colorDistance * colorLoopCount / LOOPS_TO_FINAL_COLOR;
return (256 + initColor + colorDistanceXElapsedTime) % 256;
int calcColorChange(int currentColor, int finalColor) {
int colorChange = finalColor - currentColor;
int direction = (colorChange < 0) * 2 - 1;
colorChange += direction * (abs(colorChange) > 127) * 256;
return colorChange;
void updateNeoPixels(uint32_t color) {
for(char i = 0; i < strip.numPixels(); i++) {
strip.setPixelColor(i, color);
strip.show();
// NEOPIXEL
// Wheel
uint32_t wheelColor(byte WheelPos, byte iBrightness) {
float R, G, B;
float brightness = iBrightness / 255.0;
if (WheelPos < 85) {
R = WheelPos * 3;
G = 255 - WheelPos * 3;
B = 0;
} else if (WheelPos < 170) {
WheelPos -= 85;
R = 255 - WheelPos * 3;
G = 0;
B = WheelPos * 3;
} else {
WheelPos -= 170;
R = 0;
G = WheelPos * 3;
B = 255 - WheelPos * 3;
R = R * brightness + .5;
G = G * brightness + .5;
B = B * brightness + .5;
return strip.Color((byte) R,(byte) G,(byte) B);
