All,
So I am trying to interface a couple of temperature and humidity sensors. I can read the value of the sensors every 3 minutes. I created particle variables to push those values to the cloud. I am also publishing the values to the clouds. I can see the sensor readings on particle cloud as expected. I am trying to achieve the following:
1.) Log the data in google spreadsheets. I have seen online tutorials explaining how to log to google drive. They use Javascript to read data from the cloud, that I manually need to add in a spreadhseet at the time of creation. However, I want to create a new spreadsheet every day at midnight. I am not sure how to do that automatically.
2.) I want to create a dashboard that displays several parameters and plots data. I am thinking to have a webpage (that can be easily created with widgets) that can be accessed from anywhere. I do not want to pay for live dashboard services.
3.) I would ideally like to get SMS/text message or push notifications on cell phone; in case certain events were to happen. For example, temperature change above/below threshold.
I appreciate your time and would appreciate for all suggestions and resources that you can provide. Thanks!
