5. Not relevant
6. Not relevant
7. Not relevant
8. Not relevant
9. Not applicable
10. Local Compile - every time OS compiles fine then application stage throws out warnings and errors as per the example provided
Environment Audit
Happy to share the above with you by email.
I have tried clean environment and that hasn’t worked.
/Users/wjsteen/.particle/toolchains/gcc-arm/9.2.1/arm-none-eabi/include/c++/9.2.1/tuple:1383:5: note: template argument deduction/substitution failed:
In file included from /Users/wjsteen/.particle/toolchains/gcc-arm/9.2.1/arm-none-eabi/include/c++/9.2.1/functional:59,
from ../communication/inc/protocol_defs.h:3,
from ../communication/inc/spark_protocol_functions.h:25,
from ../wiring/inc/spark_wiring_version.h:27,
from ../wiring/inc/spark_wiring_system.h:29,
from ../wiring/inc/spark_wiring.h:49,
from ./inc/application.h:42,
from ./inc/Particle.h:5,
from /Users/wjsteen/Documents/Intelligent_Furniture_Project/VSC_Projects/zioxi-locker-base/src/zioxi-locker-base.ino:142:
/Users/wjsteen/.particle/toolchains/gcc-arm/9.2.1/arm-none-eabi/include/c++/9.2.1/bits/std_function.h: In instantiation of 'static void std::_Function_base::_Base_manager<_Functor>::_M_init_functor(std::_Any_data&, _Functor&&, std::true_type) [with _Functor = void (*)(); std::true_type = std::integral_constant<bool, true>]':
/Users/wjsteen/.particle/toolchains/gcc-arm/9.2.1/arm-none-eabi/include/c++/9.2.1/bits/std_function.h:223:19: required from 'static void std::_Function_base::_Base_manager<_Functor>::_M_init_functor(std::_Any_data&, _Functor&&) [with _Functor = void (*)()]'
/Users/wjsteen/.particle/toolchains/gcc-arm/9.2.1/arm-none-eabi/include/c++/9.2.1/bits/std_function.h:675:34: required from 'std::function<_Res(_ArgTypes ...)>::function(_Functor) [with _Functor = void (*)(); <template-parameter-2-2> = void; <template-parameter-2-3> = void; _Res = void; _ArgTypes = {}]'
../wiring/inc/spark_wiring_watchdog.h:59:65: required from here
/Users/wjsteen/.particle/toolchains/gcc-arm/9.2.1/arm-none-eabi/include/c++/9.2.1/bits/std_function.h:248:4: error: no matching function for call to 'operator new(sizetype, void*)'
248 | { ::new (__functor._M_access()) _Functor(std::move(__f)); }
<built-in>: note: candidate: 'void* operator new(unsigned int)'
<built-in>: note: candidate expects 1 argument, 2 provided
/Users/wjsteen/.particle/toolchains/gcc-arm/9.2.1/arm-none-eabi/include/c++/9.2.1/bits/std_function.h: In instantiation of 'static void std::_Function_base::_Base_manager<_Functor>::_M_clone(std::_Any_data&, const std::_Any_data&, std::true_type) [with _Functor = void (*)(); std::true_type = std::integral_constant<bool, true>]':
/Users/wjsteen/.particle/toolchains/gcc-arm/9.2.1/arm-none-eabi/include/c++/9.2.1/bits/std_function.h:211:16: required from 'static bool std::_Function_base::_Base_manager<_Functor>::_M_manager(std::_Any_data&, const std::_Any_data&, std::_Manager_operation) [with _Functor = void (*)()]'
/Users/wjsteen/.particle/toolchains/gcc-arm/9.2.1/arm-none-eabi/include/c++/9.2.1/bits/std_function.h:677:19: required from 'std::function<_Res(_ArgTypes ...)>::function(_Functor) [with _Functor = void (*)(); <template-parameter-2-2> = void; <template-parameter-2-3> = void; _Res = void; _ArgTypes = {}]'
/Users/wjsteen/.particle/toolchains/gcc-arm/9.2.1/arm-none-eabi/include/c++/9.2.1/bits/std_function.h:167:4: error: no matching function for call to 'operator new(sizetype, void*)'
167 | ::new (__dest._M_access()) _Functor(__source._M_access<_Functor>());
A bit more detail of the errors reported - I’m now blind to what this is if it is in the application.
Overnight I had a thought to roll-back to the last commit on a branch that had compiled and sure enough it compiled - so not a Workbench issue - closed as solved.
[update] It appears that the code that would not build had this “algorithm” in {settings.json}
