Hey @rickkas7 or @will What is the strongest RSSI value (where -1 is strong and -100 is weak) that a Xenon will be allowed to connect to an Argon? I am seeing some weird data, where my Xenon is flashing cyan or even green but still registering that the mesh.publish is communicating, almost as if the Mesh will not allow a proper connection between a Xenon and an Argon unless it has a good RSSI value lets say of about -75.
The experiment:
So if I walk with my Xenon far enough away from my Argon, I lose connectivity, but my program shows the RSSI values using a mesh.publish, so as I walk back to the Argon I prove that Mesh.publish is working but my Xenon will not reconnect to the Argon until I get quiet a bit closer.
Data:
The Code:
I changed the code around a bit but loaded similar versions on both the Argon and the Xenon.
#include "Particle.h"
// Particle Mesh Devices RSSI distance testing
// By Jeremy Ellis
// needs po-util
// po init argon myArgonProject
// cd myArgonProject
// po config mesh-develop
// po setup-mesh
// MODULAR=n po argon build
// particle login
// particle list
// po argon ota myArgonName
#include "ot_api.h"
extern "C" {
int8_t otPlatRadioGetRssi(otInstance *aInstance);
// Event listener for "mySendToAll" event from Xenons
void myHandler(const char *event, const char *data) {
delay(5); // sends the data so an RSSI value is registered
/////////////////////////// important globals here ///////////////////////////////
int myCode = 1; // Integer to identify this device
int myCutoffInterest = 18; // which positive version of RSSI should be fast flash. default 18
bool myXenonAntennaAttached = false;
bool myArgonBothAntennaAttached = false;
bool myPublishToConsole = true; // set true for Argon or debugging
/////////////////////////////// end globals ////////////////////////////
pinMode(D7, OUTPUT);
Mesh.subscribe("mySendToAll", myHandler);
if (myXenonAntennaAttached){
#if (PLATFORM_ID == PLATFORM_XENON)
digitalWrite(ANTSW1, 0);
digitalWrite(ANTSW2, 1);
#endif
if (myArgonBothAntennaAttached){
#if (PLATFORM_ID == PLATFORM_ARGON)
digitalWrite(ANTSW1, 1);
digitalWrite(ANTSW2, 0);
#endif
// here need to get the RSSI as myCode
int8_t rssi = otPlatRadioGetRssi(0); // activate on monolithic build
Mesh.publish("mySendToAll", String(rssi));
//int rssi = myCode; // for testing
int myNumber;
myNumber = ((int(rssi) * -1) * 100) - (myCutoffInterest * 100); // for testing, makes positive and larger
if (int(rssi) == 0) {
digitalWrite(D7, HIGH); // D7 permanently on, no connection
} else {
if (myNumber <= 50){
myNumber = 50; // very fast flashing
if (myNumber > 0){
delay(50); // very quick flash
digitalWrite(D7, LOW);
delay(myNumber);
} else {
Particle.publish("Weird "+ String(myNumber), ", #" + String(rssi) , 60, PRIVATE); //shows printing an integer variable
delay(2000);
if (myPublishToConsole){ // mainly for Argon gateway unless debugging
Particle.publish("delay #" + String(myNumber), "Device #"+String(myCode) + ", RSSI #" + String(rssi), 60, PRIVATE); //shows printing an integer variable
delay(2000); // wait about 2 seconds
