In the docs, I see how to list Webhooks using the CLI; however, it doesn’t appear to grab webhooks associated with products. I also don’t see any product-related CLI functionality nor do I see any product-webhook related functionality in the API itself.
Do these exist? If not, are there plans to add them?
Yea, that’s true. It’s still a bit dissapointing. Do you know if it is possible via the API (not CLI)? Maybe I’ll just write a little python wrapper for the API to at least somewhat automate the process…
I think I read on a thread that it was possible if you just add the product ID in the payload, but I didn’t see it documented anywhere.
As you noted, the product functionality is not yet available in the CLI. Your idea of a Python script is good. Here’s the list integrations endpoint: https://docs.particle.io/reference/api/#list-integrations You can use the product endpoint like this https://api.particle.io/v1/products/:productIdOrSlug/webhooks?access_token=12345
