Library not loaded: /usr/local/opt/libusb/lib/libusb-1.0.0.dylib
I've followed the "getting started" guide to setup VSCode environment on MacOS (10.14.2).
When I attempt to flash the application using the "Particle: Flash application (local)" task, the toolchain encounters:
dyld: Library not loaded: /usr/local/opt/libusb/lib/libusb-1.0.0.dylib
Referenced from: /Users/abmh763/.particle/toolchains/buildtools/1.0.1//dfu-suffix
Reason: image not found
Before exiting (exit code : 2)
Is there any other dependencies required
can you try installing “libusb” (easiest way i’ve found is to use homebrew - brew install libusb) and see if that fixes things?
Thanks! I’ve made progress, now on to “No DFU capable USB device available” error
Many thanks, once again
for future reference, we’ve collected a handful of known-gotchas on linux / ubuntu and their work-arounds over here:
https://docs.particle.io/support/particle-tools-faq/workbench/#linux-tips
