Library is not compiling
Can somebody tell me why this code is not compiling?
I can only see an error at the bottom of the IDE saying "build didn’t produce binary Error: Command failed…
But when I click it doesn’t show me anything
That’s failing because there are two L3G4200D files, one with a .cpp and one with a .ino extension. This won’t work because both files compile to L3G4200D.o, one overwrites the other, and then the build gets confused. Rename one of them, for example L3G4200DTest.ino.
thanks!, it worked!
