Hello @rickkas7
I have been trying to understand the 3 topics i found on the forum regarding the use of a micro SD card with the particle photon. Aside from this one, the other two are:
(In the above disccusion the Trymefirst program is mentioned which is used to test if the SD card and photon are communicating which i do understand)
I am still relatively new to particle and this will be the first time that i am using an SD card. I am struggling to determine which to use for the purpose of logging weather data to an SD card between the serialLogHandler and SdCardLogHandlerRK methods. Aside from the syntax changes what the difference between these two and which would be the best suited for my purpose? I am sorry if this is a stupid question, if it is then i don't quite understand how to work with SD cards. In that case can you please send me a few links that i can read to better understand this. Thanks in advance.
