Now that the Firmware Library Manager is being tested, is there a plan to make libraries compatible with standard Arduino, particle, AND raspberry pi?
I ask mostly because I had a project for a particle board that used a library, and when I moved to the RPi for that project, I had to do some minor changes to the library to make it compatible. I have more questions, but first I’m interested in the road map for keeping libraries compatible with all devices.
