According to the docs, I should be able to search/replace using the CTRL-H shortcut, but nothing happens when I try to use it.
CTRL-F works fine for find, but no replace. I’ve tried it on the latest Chrome & on IE 11.
thanks,
-Steve
thanks,
-Steve
Unfortunately Build IDE doesn’t support Ace’s replace feature. For some more advanced text manipulation (code completion, snippets, multiple cursors) you can use Particle Dev.
