Hey everyone,
I’ve been trying to set up local compiling on the particle photon and I seem to run into issue after issue. Right now my biggest problem (or so it seems) is that every time I try to flash the device locally, the device goes into safe mode.
A little background:
I followed the instructions on flashing the photon locally on the gitindent preformatted text by 4 spaceshub firmware page. I have downloaded the GNU tools (v4.9) GnuWin32 as well as MinGW and set the path the respective path variables.
When I run the dfu-util -l in the command prompt I get the correct DFU device found (2b04:d006)
Following the instructions on the Github page, i try running “make clean all PLATFORM=photon -s program-dfu” on the modules folder of the firmware, however I get the following error:
C:\Particle2\firmware\modules>make clean all PLATFORM=photon -s program-dfu
/usr/bin/bash: arm-none-eabi-gcc: command not found
../build/arm-tools.mk:43: *** "ARM gcc version 4.8.4 or later required, but foun
d ". Stop.
As suggested in some threads as well as in the instructions, I try running the same command but in the main folder. I get a successful file download HOWEVER the photon enters safe mode:
C:\Particle2\firmware\main>make clean all PLATFORM=photon -s program-dfu
Can't locate Archive/Zip.pm in @INC (you may need to install the Archive::Zip mo
dule) (@INC contains: blib/lib lib /usr/lib/perl5/site_perl /usr/share/perl5/sit
e_perl /usr/lib/perl5/vendor_perl /usr/share/perl5/vendor_perl /usr/lib/perl5/co
re_perl /usr/share/perl5/core_perl .) at /c/Particle2/toolchain/MinGW/msys/1.0/b
in/crc32 line 7.
BEGIN failed--compilation aborted at /c/Particle2/toolchain/MinGW/msys/1.0/bin/c
rc32 line 7.
text data bss dec hex filename
6372 156 596 7124 1bd4 ../../../build/target/user-part/platform
-6-m/user-part.elf
dfu-suffix (dfu-util) 0.7
(C) 2011-2012 Stefan Schmidt
No valid DFU suffix signature
New DFU suffix added.
Serial device PARTICLE_SERIAL_DEV : not available
Flashing using dfu:
dfu-util 0.7
Copyright 2005-2008 Weston Schmidt, Harald Welte and OpenMoko Inc.
Copyright 2010-2012 Tormod Volden and Stefan Schmidt
Filter on vendor = 0x2b04 product = 0xd006
Opening DFU capable USB device... ID 2b04:d006
Found DFU: [2b04:d006] devnum=0, cfg=1, intf=0, alt=0, name="@Internal Flash /
0x08000000/03*016Ka,01*016Kg,01*064Kg,07*128Kg"
Claiming USB DFU Interface...
dfuIDLE, continuing
Dfu suffix version 100
Downloading to address = 0x080a0000, size = 6544
File downloaded successfully
I tried manually downloading the system part 1 and 2 .bin files and flashing them myself to the appropriate addresses but that yields the same results. (I flashed the system part1 to 0x8020000 and part2 to 0x8060000)
I read in some threads that this might be an issue with the crc32 (of minGW) not working well. I connected the device to serial and used the s command and noticed that in some of the instances the vv and vc numbers don’t match. I guess I am dealing with some different version of crc32 but I am not sure how to fix this.
Did anyone have this issues or knows about this that can direct me? I am running on windows 7.
Any help is greatly appreciated!
